PBComputer
- Carlisle, Cumbria, UK
So yesterday I was in the office, just winding down for the day when I get a call from a customer, they had an electrician in fitting 3 x 3 phase power and 3 x single phase power. They had a network cable from the house to a switch half way, then another switch at the far end. They installed the first network cable. and I punched it down and it worked. Until the electrcican came and installed the new power cables, they also can a new network cable as (mine was wrong, according to the electrician/sparky)
He decides to run the new network cable (it was CAT5 STP) right next to the 6 x power lines going to the other buildings. GREAT!
Then says it does not matter how you punch down as long as its the same each end. (it wasn't)
So I went got it all tested, every socket was wrong on the network. So fix all that, and test, they have interent in the far workshop, I's only then I discover it's 197m!!! in one run. Not ideal. But it's working and they will sort it when it goes wrong again.
He claims it would be fine how he installed it, even the customer questioned running it next to the power cables, to be told "It'll be reet." (It will be alright)
If there was line of sigh I would use some Ubiquiti networking gear and make it all wireless but I can't
