HCHTech
- Pittsburgh, PA - USA
Stopped in to a small MD office (Doc is a residential customer of mine) today after a panic call for help. Their single computer won't boot. It's a small Thinkserver, TS140, I think, running Win7 Pro. Incredibly, he says he has a backup. I decide to take it to do a proper backup & diagnosis. Once I get it back to the bench, I see there are two drives in a RAID1. One drive is failing according to the RAID configuration screen. There's no RAID card, the drives are just plugged into the motherboard SATA ports and I can't make out any numbers by the ports. I remove each drive individually and run it through gSmartControl. Sure enough, one is failing and one is good.
The drives are Seagate Constellation ES, 500GB. I don't keep anything like this in stock, so I decided to order one and temporarily use a WD Blue to get him back up and running. The rest of the hardware passed my tests, so after making an image of the good drive, I mount it along with a new WD Blue and boot it up and set the RAID to remake the mirror. I took it back to his office so he could use it while we waited on the new drive.
I'm going through all of this and wondering if I should have just pulled the bad drive onsite (assuming I could have identified it). I'll bet it would have booted then. He would have lost the protection of the RAID while we waited for a new drive, but would have been back running a few hours sooner. I think I did the right thing, but I'm not sure. What do you think?
