Stubborn PC
repairit
Jacksonville, FL
Ok, I have a custom gaming rig in the shop a power issue. Running EVGA x58 SLI with i7 proc. Also running 2 SLI linked EVGA video cards (not going back into that machine right now unless neccessary.... mad at it :p), an XFI PCI sound card as well as 3-6Gb Ram in a triple channel config. Also running a Raid0 on 2 drives with a non raid 3rd drive connected as well.
The power turns off randomly. Sometimes I can stay up for a minute or 2, most of the time, its less than 30 seconds. I have torn down the machine to just the board, drives and ram with a known working pci-e video adapter and still having issues. I have tested the power unit and it checks out. I also replaced the MB with a brand new RMA that was sent over and still doing the same thing. Checked CPU during switch and seems to be in tact. I have checked the BIOS after a drop in power and temps seem to be within spec.
Anyone got any ideas? I'm ready to punt this thing out the window!
I would have to agree with the above posts but i would be checking the minimum power output required for you graphics cards and make sure that your power supply meets it. I know a lot of decent cards these days require 550watts so i would be going for a 1000watt PSU, you can hook up a known working PSU but if it doesnt make the requirements then there's no point.
I got nothing that big laying around. The current unit in the machine is a 1000w PSU. I tested it on a standard PSU tester and all of the plugs came out ok, but I will pick up another PSU tomorrow and let you guys know how it goes.
The problem with standard PSU testers is that it does not test under load. I have seen several PSUs that have passed a standard PSU tester fail under load.
If the motherboard has a voltage meter in the BIOS, you can look there to see if there is any change under load and/or just before it shuts itself down.
I think I may pickup a spare power supply tomorrow, just to try out.
When did EVGA start making motherboards?
Second question why would someone build a high end system with a generic board. Thats like putting an FIC in it. Do you have another board you can use to test everything on? ASUS maybe?
Lol, yeah, was a bit surprised myself. I already took the components and tested them in my bench machine individually and they checked out alright. The problem is I don't have a spare board to run all of the components or the i7 CPU in to test so I'm working things seperate as much as I can. Hopefully the PSU works out. On the up note, replacing the board let me test and fix a Raid0 issue that I had on the old board. I'm over this machine.
Well my moneys on the PS on mobo. If the PS does not work out I would try and source a better mobo for it and hopefully that will solve it.
I see this all the time and I think its kind of funny. Customer spends a zillion dollars on a high end system just to put a cheap generic motherboard from Fry's in it. But hey those guys keep us in business don't they, lol.
Actually that EVGA board is a nice board. Gets great reviews on tigerdirect and the :classified: model is sweet.
Nother Update: I was poking through the BIOS and found the settings for the power button. It was set to 1 push off. I set it to 4 seconds and so far so good. Checked the pins and they seem intact. I guess a short on the switch itself? I hate chasing my tail only to find something completely different and mentally painful. Guess I know how my dogs feel when they finally catch their tail and wonder why it hurts.
