vitalgeek
- Orlando, FL
Here is what I currently have and it gets the job done time and time again, I just want to see what you all think I could do to streamline it. This is in order (i.e. run rkill first, then tdss, etc):
To be honest, I want to remove or modify the things that take forever like mbam, defrag, chkdsk, sfcscan, updates, etc. What would you do?
Thanks
rKill - scan and manually remove
TDSSKiller - scan away
CCleaner - Use to empty the recycle bin, clean temp folders and cookies, etc. When done with cleaning use the registry scanner to fix the registry.
Autoruns - Remove all unverified/unnecessary startup processes.
Process Explorer - Remove all running suspect processes.
Cintrep - Internet "fixer-uper" lol(this is one I think I might be able to get rid of, though it has helped before. I feel it can keep the first call resolution down)
HiJackThis - Scan with HiJackThis and scan the results at www.hijackthis.de.
Mats WinSecurity - Tool from Microsoft that fixes commmon problems.
Malwarebytes - Run Malwarebytes to scan for malware.
Disk Defrag - Defrags Disk
Check Device Manager for outdated/uninstalled drivers
Open CMD and use "chkdsk c: /f /r" and "sfc /scannow"
Run updates
Talk to cx, see if they need anything, inform of future steps, offer to remove installed programs.
Note: if in shop, clean physically! Remove dust, wipe down exterior, etc. Also visually inspect the motherboard for swollen capacitors and brown/darkish
spots and test the power supply.
Thanks
