We have a client with a 3 monitor setup that started having some strange behavior. We are being told this has happened since it was set up, but it was never reported by the users.
3 monitors, 1 running off intel graphics, the other 2 running off a gtx 1050 gpu. 2 are using HDMI, 1 is using displayport. System is a kaby lake i5, 32GB ram. Win 10 Pro Creators update.
When 1 user logs in, everything is fine. But, if a 2nd user logs in, the "main" monitor goes black as soon as you type in your password and press enter. If you turn the power off on the monitor and then flip it back on, it comes back without issue, but that seems to be the only way to get it back short of a reboot.
Trying to replicate this in a remote shows all 3 displays just fine, so I was initially leaning towards a hardware problem.
i tried swapping the monitors to different ports on the graphics cards, but this just moves the problem to a different screen. So it doesn't seem to be a faulty monitor.
I made sure all graphics drivers are up to date, this didn't help.
Right now they are getting by with simply power cycling the monitor, but thats a short term fix until I can hopefully figure this out.
Any ideas? I realize this is pretty specific, at this point i'm more curious than anything.
