**solved** Imac 8,1 Fan issue
4ycr
West Lothian, Scotland
This is for my friend and having looked at the teardown, it is above me but before he went somewhere I thought I would ask here.
The fan is at high speed constantly, this apparently happened after a repair years ago but he has just asked me. The repair was for a faulty hard drive.
Is this fixable in the first place as it sounds like a sensor fault or could it just be a cable not being plugged in properly?
Thanks in advance
You don't say which model iMac, but here's the story. iMacs run notoriously hot, and have few ventilation slots. They use the aluminum housing as a giant heat sink.
iMacs have a temp sensor on the hard drive used to control the speed of one of the fans. The older ones used a sensor that attached to the drive with adhesive, the newer ones have a special header on the drive that uses the drives internal sensor.
Standard replacement drives have a different header. Left unconnected, no temp signal is sent to the logic board. The board then defaults the fan speed to it's highest setting, making the computer sound like a jet plane and annoying the users.
Here is an article describing whats happening.. http://blog.macsales.com/19617-diag...ed-issues-after-upgrading-the-main-hard-drive
You can rewire the connection on some iMacs.
You can buy one of these http://eshop.macsales.com/item/OWC/DIDIMACHDD11/
Or you can use one of the fan control utilities on the market to override the sensor and set the fan at a constant speed just below hearing level, but high enough to keep the drive cool.
Don't work on macs as much anymore, but back when I was apple certified (around 2009), I used to use smc fan control. It may help with what you are doing, and it will allow you to create profiles that specify when temps get to level x for example have fans go to percentage xyz. Nice little utility.
Thanks for your help macs fan control worked well. It showed all temps as normal but he CPU fan went full speed anyway. It is now controlled.
