SOLUTION: Windows 10 1709 Cannot Connect to network shares
NETWizz
You folks ARE going to very likely find some customers (predominantly businesses) who after the November 14th, 1709 Windows 10 can no longer connect to some network shares, and everyone is going to be besides themselves raising a stink about it.
Essentially SMBv1 was used up through XP/2003
Windows Vista/Server 2008 try to negotiate SMBv2
Windows 7/Server 2008 R2 try to negotiate SMBv2.1
Windows 8/Server 2012 and tries to negotiate SMBv3
Windows 8.1/Server 2012 R2 will try and negotiate SMBv3.0.2
Finally:
Windows 10/Server 2016 will try and negotiate SMBv3.1.1
Windows 10 ALL versions will Disable SMBv1/CIFS Server by default.
Windows 10 Education/Enterprise disable SMBv1/CIFS Client & Server by default.
Hence, a customer with Windows 10 Enterprise in a network with leftover Windows Server 2003 R2 and older will NOT connect.
Solution - Check here... get and paid:
OR. Upgrade their servers... Get paid MORE...
You should get written verification of approval that you enabled SMB 1.x because you are opening a large security vulnerability on their network. This would be the time to explain why those old WinXP and Server 2003 systems need to be retired once and for all.
It's not a huge vulnerability. It is still a supported windows feature if installed. The vulnerability is in the unpatched Server 2003 box you leave alone and don't upgrade.
  • Like
Reactions: GTP
There is a patch for that specific issue for XP and 2003, it just has to be manually applied.
But at this point all of my stuff that old is hiding behind a firewall, you have to RDP to a system inside the bubble to access that old stuff. XP is dead, time to move on.
