Appletax
- U.P. of Michigan
I've reinstalled Windows 7 SP1 on three laptops and all three had the high CPU usage and memory leak caused by SVCHOST.exe. Tried many, many things to fix the issue and found a solution that has worked on the latest laptop I've worked on.
The laptop I was working on is done and updated 100%. SVCHOST.EXE did not gobble up RAM or CPU time during the entire update process.
Here is my solution
Please let me know if this procedure does or does not work for you
Here is my solution
- Install Windows 7 and do NOT enable automatic updates
- Install drivers
- Manually install Windows 7 SP1, if needed
- Install latest Windows Update Agent (this may not be necessary)
- Install offline updates with Autopatcher (important first and then recommended - don't install IE 11 because it doesn't work)
- Change power settings to now allow PC to sleep or hibernate
- Turn on automatic Windows Updates and leave computer alone
- Keep updating the system until there's nothing left to update
- Windows Update Client for Windows 7: June 2015 did not help
- After installing Windows 7 SP1 with automatic updates, leaving the computer alone for potentially a long period of time may eventually lead to the system updating, despite the SVCHOST.exe issue
- On the last laptop I worked on, I did this and it took 1.5 hours to find and apply the first round of updates
- The next round of updates were the big one: 192 important updates
- I let them download and the progress was stuck at 0% for at least half an hour
- Went to bed and let them download and install overnight. Woke up to the updates being stuck at number 142 and had to do a hard shutdown and start over.
