Solid State Drive
parttimetechie
Hey All,
I am building a computer in the next week that the customer wants a SSD 2.5" drive. I've never built a PC with an SSD in it. Couple of questions
Will the standard 2.5" drive bay in a case hold the drive alright?
Will the drive be susceptible to electro shock and data loss in a power failure or hard reset?
Does the SSD need to be insulated in the case any particular way?
Does the SSD need specific proprietary power or SATA cables to interface with a modern motherboard?
Thanks
Hey All,
Yes, it uses the same mounts as a regular 2.5" drive.
I'm not 100%, but I would assume so.
Not that I'm aware of, and not that I have done so on any build so far.
Nope, standard SATA Data/Power connectors.
NP. :)
It will only lose data if that data is currently being written or in the cache, just like a physical drive.
No.
The downside to SSDs are the expected life spans of programmed/erase states of SSDs to Physical hard drives. Physical hard drives have a programmed/erase cycle of 1,000,000 or some extremely high number like that. SSDs on the other hand (Especially the brand new ones) have a programmed/erase rate of 5,000. Still, this can last a LONG LONG time before you completely run out your cycle, just beware of this if you're going to be constantly writing/erasing on the SSD.
Anand has a great article on this exact problem with SSDs: http://www.anandtech.com/show/4159/ocz-vertex-3-pro-preview-the-first-sf2500-ssd/2
Edit:
For your customer, tell him to NEVER defrag the SSD. Ever. Ever ever. It sounds counter-intuitive but it's wears the SSD down faster, giving it a shorter life.
Good thread.
It answered a number of questions I was going to look up.
Cheers
Sent from my iPhone using Tapatalk .... Whilst proclaiming the machine fixed, grabbing the cash and running like hell.
