Majestic
- Montreal, Canada
Hi,
I have a bit of a dilemma here..
I quoted a client 2 hours (max) to fix his constant fan that goes on and off on his Compaq Presario v2000 laptop. Well I've already worked 3 1/2 hours and after having closed it up the same problem is there. I blasted the heatsink and cleaned the fan with both alcohol and compressed air and while the fan is a bit quieter it's still loud and annoying. His sempron 3000+ mobile chip is running at 60 - 62 Celsius average. The fan seems to go on and off every minute or two. Quite annoying.
Anyway, long story short-- I have not found the solution to this problem. I suspect -perhaps- it's the fan assembly that needs to be replaced, but I could be wrong. Also, he is running Windows XP with 384 megs of ram which I believe might cause an issue (if it keeps going to the hard drive for ram then the fan starts going..).
So seeing as I did not solve his issue BUT I put in 3 1/2 hours into his laptop I'm not sure how to go about this? Any advice would be greatly appreciated
Thanks,
Majestic
Thanks,
Majestic
