Here are the details.
Client has Comcast SMC Gateway with an RV082 firewall configured with a static IP. Two 24 port switches, WAP, couple of IP printers, Windows 2008 server, Datto box, 2 desktops, and 2 or 3 wireless laptops that come and go.
Back in November I get a call that the client is losing internet daily at the same time between 3:15 and 3:30. It will come back on it's own after a few minutes. They called Comcast first which came out and said the problem is not on their end. Shocker. They waited a week before they called me. When I actually go onsite it was after the time change so now the outage is after 2pm. I'm thinking something is rebooting at the same time daily. I've ruled out any scheduled event that could be taking place. The RV082 has lengthy up time.
DAY1: I arrive onsite, get plugged in with laptop and start some pings and basically wait. Sure as the sky is blue 2:19pm internet goes out. At this point I'm connected to the RV082 directly. I have pings to their server, RV082, 208.67.222.222, and 8.8.8.8. Only the WAN IP's are dropping. I unplug my laptop from RV082 and plug directly into the SMC 4 port. Pings come back instantly. I switch back to RV082 and pings are still replying. It's an old RV082, they've been known to die, so I swap it out for a known working RV082 that I brought with me and tell them I will be back the next day.
Day2: Onsite, get plugged in. 2:19pm, WAN pings start dropping. I know it's not a firewall issue. This time however, the connection does not come back right away. So I pull the uplink to the primary switch and the connection comes back. I monitor it for some time and tell them I will be back again the next day. It's difficult to troubleshoot this when it's not dropping packets.
Day3: Onsite, get plugged in. This time I disconnect RV082 from SMC, connect laptop to SMC. 2:19pm comes along, no loss of connection. Weird. So this time before I leave I install a spare switch, update firmware on WAP, configure SMC to have LAN IP as RV082, and basically have them operating on all spare equipment excluding the SMC.
All along I will add that at no time did I ever have dropped packets on internal lan devices such as server or printers.
Day4: Onsite, get plugged into SMC, 2:19 no loss of connection. I reconnect all original equipment and basically put everything back to square 1. The only change that has been made thus far is updated firmware on an Asus WAP.
Day5: Monitoring remotely. 2:19 no loss of connection. Hmmm, what could it have been.
Fast forward to last Friday and I get a call the problem is back. This time they lose connection at 12:19pm. WTF? It's as if it jumped an hour per month. It started happening the beginning of last week so they say.
They called Comcast again, tech comes onsite, not their problem. Shocker. An employee was working on Saturday and states he did not lose internet at 12:19. Monday I go onsite. Get setup. This time at 12:19 I notice I do not actually lose connection but it slows down so slow you would think the connection is lost. I start some traceroutes to a few WAN IPs and monitor. Everything looks okay. Pings are all good as well. I monitor remotely on Tuesday due to snow storm. Connection slows at 12:19. I can actually maintain an RDP connection to their terminal server albeit slow as ever. It was difficulty to do anything. I could see pings and tracert responses but mouse and keyboard input was very spotty. After 20-30 minutes of this I rebooted the RV082 and the connection came back. I looked at the tracert logs and can see the first hop after the modem is where the packet loss occurs. It's the CMTS of Comcast. So now I will call Comcast and present my findings. What on earth could be happening at the same time every day for a few minutes that could cause this? I've Googled and cannot find anyone reporting similar issues. I'm going to request a new SMC from Comcast but I do not think that is the issue. I'm using VisualRoute so I have a lot of comparables to show Comcast.
What are your thoughts and has anyone experienced anything like this before?
