Security Cams?
I think I'm convinced on the Unifi Video (my first Unifi WAPs arrived yesterday). What would you recommend for a PoE switch? Right now they have two Linksys 10/100 24 port switches, so it's about time for some upgrading, but really the 10/100 haven't causes any problems since they don't have much for network resources. So maybe just one 24 port switch with PoE (the second switch doesn't have too much on it right now anyway) would fit the budget better.
Also, they have an office (with one computer) not far away, but it have it's own internet connection and they want one camera there. Any good way to set this up with unifi video where I won't have to setup a second NVR? The Unifi NVR says it has multi-site support, but I'm not exactly sure what they mean by that and I haven't found much information on it.
And I can't seem to find any information on what generation the cams are that my supplies have, any tips?
Just snag one of Ubiquiti's own POE switches.
It's multi-site just like their Unifi wireless controller software....drop down menu to work with the site you want.
It seems like most people build/install their own NVR's here? I'm quite surprised by that.
We mainly use Dahua systems with their own NVR's such as this 8-channel one - http://www.amazon.com/Dahua-NVR4208...UTF8&qid=1446068016&sr=8-2&keywords=dahua+nvr
It has a built in 8-port POE switch. So to connect a camera you simply plug one end of a CAT5 into the back of the NVR... the other into the camera... done!
The only downside is when you buy for example an 8-channel system it really is limited to 8 cameras. You want to upgrade to 10... you need a whole new NVR.
Just wanted to let you know that with the Synology $50 license (Which you can get for $40 at Synnex and possibly others) that this is a lifetime license and can be transferred if you do upgrade your NAS in the future.
Yeah we also either need a cablers license which has not been an easy process to get here in Aus or usually we get an electrician who also has the cabling licence.
FYI - Just from a legal stand point - here in Aus we are required by law to have a security licence to install security cameras.
^^^ This is very important. And not just the installation part. Every jurisdiction has varying regulations related to operating a video recording system. In my area the EU has to post a sign advising video recording in progress. Employees also need to be advised as well as sign a document they have been advised of this activity.
As far as headless, all of the good ones are headless with an option to hook up a local monitor. Many allow direct connection to the cameras, if they are IP, or to the DVR. Either directly through the site network or via the vendor's website. Personally I prefer to have the direct connection since I do not want the feeds to be going to someone else. In those cases you can use Dynamic DNS, which I do not recommend, or a fixed IP, obviously the preferred method.
Regarding NVRS HIK-Vision is excellent and they have a number of companies that whitelable their NVRS and cameras for a fraction of the price.
With regards to Ubiquiti cameras I have never tried them but their AP are a dream to work with just remember they are 24v poe instead of the standard 48v so you must use their injectors in order for them to work or their switches.
So in theory, I should be able to port forward the one Unifi cam and have the NVR at the main office doing the recording?
I kind of suspect that the small office doesn't have a fixed IP though :(
You need to forward the ports to the NVR rather than the camera. The web interface for the cameras is too limited to use for monitoring.
And the NVR software works fine using DynDNS or similar if you don't have a static IP.
I'd be very very careful forwarding any ports to cameras or vendor systems - or to any embedded systems like that for that matter. Those systems are basically thrown out into the world and never updated, and they quite often have major security problems that can be exploited if they're reachable from the real world. The issue isn't so much someone having the ability to see what the camera is showing, it's having the ability to log in with a hard-coded backdoor password like "0000", then either take advantage of security issues (e.g. bad URL handling leading to a busybox shell on the embedded Linux) or upgrade firmware with something that gives them access to the entire network.
At a bare minimum I'd require port knocking to open the connection, but I'd be uncomfortable even with that - a VPN is a much better option.
We use Hikvision for most jobs and they are great. Looking at Avigilon for the top end, as they have some really cool analytics. Still tempted to try the Unifi Video stuff as I use their wifi stuff all the time and can't fault it...
So I did end up going with the Unifi cameras. The NVR computer is running Ubuntu and it has been rock solid, and easy to set up. I've used some bullet and some dome cameras. I like the bullets better because it is easy to adjust the focus. I'm not sure how you adjust the focus on the domes, I read something about people creating a special tool to do it, but maybe that was just for the aircams.
Just the regular. I kind of wish I had the pro at the one spot because if they want to be able to capture licence plates, and it would be nicer if it was just a little bit clearer. With the regular UVC there they might be guessing at one of the letters/numbers of the plate. However it is quite the price jump to go to the Pro.
