Scripting help
Doc+Com
Franklin, IN
Hi guys,
I'm hoping someone on the forum can help with a scripting problem that I'm trying to solve. I've exhausted all of the options that I know of and I admit, I'm not the most knowledgeable in this area and have had a few others offer suggestions but I still don't have a solution so thought I'd throw it out for some advice.
The scenario is;
What I want is a script to "get" and "put" files to a couple of sftp hosts.
My biggest issue is that the files I am "Getting" need to be renamed as they are pulled, and there might be 1 to many files. I don't have to rename the files as I "put" them up to the sftp site. However, once I have a successful "put" I must move the files on the local host to a different folder.
I am useless at Powershell scripting, so I didn't even put my script attempt up here. I tried it using the WinSCPnet.dll, but I am up to any solution. I tried using the ipswitch ws ftp but found it even less flexible than the free WinSCP.
I have uploaded the batch and SCP scripts to separate text files for review.
If anyone has some input I would really appreciate your thoughts/ideas.
Source: Stackoverflow. I have used this in the past. It was faster than typing it out for you..LOL
Upload:
Code:
@echo off
SET FTPADDRESS=%1
SET FTPUSERNAME=%2
SET FTPPASSWORD=%3
SET LOCALDIR=%~f4
SET REMOTEDIR=%5
if "%FTPADDRESS%" == "" goto FTP_UPLOAD_USAGE
if "%FTPUSERNAME%" == "" goto FTP_UPLOAD_USAGE
if "%FTPPASSWORD%" == "" goto FTP_UPLOAD_USAGE
if "%LOCALDIR%" == "" goto FTP_UPLOAD_USAGE
if "%REMOTEDIR%" == "" goto FTP_UPLOAD_USAGE
:TEMP_NAME
set TMPFILE=%TMP%\%RANDOM%_ftpupload.tmp
if exist "%TMPFILE%" goto TEMP_NAME
SET INITIALDIR=%CD%
echo user %FTPUSERNAME% %FTPPASSWORD% > %TMPFILE%
echo bin >> %TMPFILE%
echo lcd %LOCALDIR% >> %TMPFILE%
cd %LOCALDIR%
setlocal EnableDelayedExpansion
echo mkdir !REMOTEDIR! >> !TMPFILE!
echo cd %REMOTEDIR% >> !TMPFILE!
echo mput * >> !TMPFILE!
for /d /r %%d in (*) do (
    set CURRENT_DIRECTORY=%%d
    set RELATIVE_DIRECTORY=!CURRENT_DIRECTORY:%LOCALDIR%=!
    echo mkdir "!REMOTEDIR!/!RELATIVE_DIRECTORY:~1!" >> !TMPFILE!
    echo cd "!REMOTEDIR!/!RELATIVE_DIRECTORY:~1!" >> !TMPFILE!
    echo mput "!RELATIVE_DIRECTORY:~1!\*" >> !TMPFILE!
echo quit >> !TMPFILE!
endlocal EnableDelayedExpansion
ftp -n -i "-s:%TMPFILE%" %FTPADDRESS%
del %TMPFILE%
cd %INITIALDIR%
goto FTP_UPLOAD_EXIT
:FTP_UPLOAD_USAGE
echo Usage: ftpupload [address] [username] [password] [local directory] [remote directory]
echo.
:FTP_UPLOAD_EXIT
set INITIALDIR=
set FTPADDRESS=
set FTPUSERNAME=
set FTPPASSWORD=
set LOCALDIR=
set REMOTEDIR=
set TMPFILE=
@echo on
Download
Code:
@echo off
SET FTPADDRESS=%1
SET FTPUSERNAME=%2
SET FTPPASSWORD=%3
SET LOCALDIR=%~f4
SET REMOTEDIR=%5
SET REMOTEFILE=%6
if not defined REMOTEDIR goto FTP_UPLOAD_USAGE
if not defined REMOTEFILE goto FTP_UPLOAD_USAGE
:TEMP_NAME
echo cd "%REMOTEDIR%" >> %TMPFILE%
echo mget "%REMOTEFILE%" >> %TMPFILE%
echo quit >> %TMPFILE%
del %TMPFILE%
:FTP_UPLOAD_USAGE
echo Usage: ftpget [address] [username] [password] [local directory] [remote directory] [remote file pattern]
echo.
:FTP_UPLOAD_EXIT
set FTPADDRESS=
set FTPUSERNAME=
set FTPPASSWORD=
set LOCALDIR=
set REMOTEFILE=
set REMOTEDIR=
set TMPFILE=
@echo on
I really appreciate your help pixelated, I'll absorb some of the info from the link and then see what I can do.
Many thanks.
