crabig
- Mobile, AL
OK, first things first. Windows Server is not my strong suit. When I first installed this setup, 18 months ago, all was working fine, but I had someone working for me to do the server setup, and all the clients were on XP.
Over the last two weeks, I have changed all the XP machines over to Windows 7 Professional.
There are four regular clients, one Windows 7 machine that is acting as a file server (everything is in the \Users\Public\Documents directory).
One machine running Server 2008 R2.
I am having an issue with the machines showing up in the Network Places under My Computer. The server and File server don't even see themselves in the network listing, and as far as the rest go, I have listed them below.
We have Server, File Server, and Machines A-D.
Server sees Machine B & Machine C
File Server sees Machine A, Machine B, & Machine C
Machine A sees itself, Machine B, Machine C, & Machine D
Machine B sees itself, Machine A, Machine C, & Machine D
Machine C sees itself, Machine A, Machine B, & Machine D
Machine D sees itself, Machine A, Machine B, & Machine C
The Server is the primary DNS for all other machines.
I can ping, and connect via Computer Name, so DNS is functional. I just can't see all the machines in the Network View. Also, there are two folders on the File Server that are shared amongst all users. One is Misc. Data, and the other is a Scans folder that files from their printer/scanner write to. If I enter the full path manually to map the network drives, the will connnect, but drop off after a while. I cannot Browse the network for them because the Server and File Server do not show up in the Network List.
I'm at a bit of a loss here on what may be going on, and would love an assist from some of the more knowledgeable network folks on the forum.
Thanks in advance.
Thanks in advance.
