autumn
- Geelong, Victoria, Australia
G day all
I'm having an issue with a SBS 2011 server network. So there is the SBS server, an 2008 Server std (for remote desktop), Dlink DSR500N switch and about 15 computers.
Now the issue looks like an DNS issue, as the workstations will take several tries refreshing before the page will be displayed.
I've tried the regedit fix below, I've disabled IPv6 on Workstations, I have read that it could be a Dlink modem issue (not to sure if that's meant to be router or modem, changing the DSR is more of a problem as I've VPN's set up as well, I have replace the modem, which is in bridged mode). I've set the forwards to local ISP servers as well as opendns servers. Each step seems to have fixed it a little but still not 100%.
I don't think it's the router as I've set a couple of the workstations manually to the router or external servers and it seems to be 100%.
any help would be greatly appreciated.
Reg fix.
"HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DNS\Parameters
3. On the Edit menu, click New, click DWORD (32-bit) Value , and then add the following value:
Value: MaxCacheTtl
Data Type: DWORD
Data value: 0x2A300 (172800 in decimal = 2 days)"
Reg fix.
Value: MaxCacheTtl
Data Type: DWORD
