timeshifter
- USA
Have a customer who has an old application, Telemagic, that they need to reference every so often. In the past I've tried to get it to work on Windows 7 but ended up running it in XP Mode. Now it runs in VMware Player on one machine on the owner's laptop.
He recently asked me to do the same setup for two other users.
Note 1: the data from Telemagic has already been converted to their newer system, but there is some info that they can only get from the real thing apparently.
Note 2: it's only used from an historical perspective, so if it's on multiple machines they don't have to be networked or talk to each other, essentially read only of old data.
Note 3: it will rarely be used, doesn't need to be more than one at a time. A user may get in once a month for example.
We are in the process of ordering a new server. It will run a Hyper-V VM of Windows Server 2016. Will be an AD and file server and share Sage. A couple of users may access Sage by Remote Desktop.
Since we'll have Sage in a shared environment was thinking it would be cool to share the XP instance to run Telemagic as needed.
Trying to figure out how to do this and do it securely.
If the new server is running Windows Server 2016 Standard with their new "server" being a Hyper-V VM, then that would leave one license or instance of Server 2016 we could still spin up. If I run XP under a Hyper-V VM on that server then how do they access it? Don't want to enable any network adapters for XP, so no RDP to it. If they RDP to the Hyper-V host then it's now doing a new role and you've burned one instance.
But, as I write this I think I have a solution: the end user can connect to the Hyper-V server with the Hyper-V remote management tool and access the XP instance that way? Does that work?
Any other ideas? Or should I just punt and install VMware or Virtual Box on individual PCs, which isn't anywhere near as cool or fun or help sell a server.
