Removing rounded off screws
Martyn
Bedfordshire UK
I've just got a Dell Inspiron 1535 laptop in for a power jack replacement and it looks like they have had a go themselves and rounded off a lot of the base screws. :mad: I've never had a problem with screws before, what do you use to remove them? A Dremell drill maybe? I've removed them on car bolts with extractors but nothing this small, any tips?
With recessed screws your best bet is either glueing a screwdriver to each screw head (which is a very slow method), or drilling the heads off and then drill out the screw shaft with a suitable small drill (tricky). But if you are removing the board anyway, go nuts ;)
Or get a donor laptop from eBAY (one with a smashed screen).
Just make really sure there's no metal bits left when you fit the new board.
any tips?
Charge them extra for making you put more time into it.
A small drill is probably the way to go. Take the hard drive out first and if possible, the LCD. I hate drilling on a laptop with LCD still in it. The vibrations CAN'T be good. Luckily I can't even remember the last time I had to drill off a screw head.
Right managed to get them all out bar one :( Normally with a screw you can hacksaw a slot in it but they are recessed on laptops making it impossible.
Automobile mechanics use what's called an "easy out" to remove screws and bolts with deformed heads. The job still requires drilling into the top of the screw to create a hole for the easy out to fit into but they're the best tool for this type of situation.
I don't know if they make a size that's small enough for laptop screws but it's worth a phone call to an auto parts store or a machine shop to find out.
Yes I've got those but these are small. Just the one although I might not need that one out :)
Lefthand drills work pretty well; if the screw isn't too tight sometimes the drill will bring it out.
My preferred method is a Dremel with a cutting disk on it. On the stripped out screw head, cut a straight line across the top, deep enough for a flat head to fit. Now you can remove it with a flat head.
Has worked wonder since my Marine Corps days. Works well on computers too, just be careful ;)
Yes good idea, something with a small diameter disk. Done it plenty of times on larger screw where you can get access to the head with a junior hacksaw(not computer repairs), good thinking, thanks.
Anytime. Hopefully it all works out. Just remember to be careful, Dremels are very fast haha.
You should purchase a small size #1 screw extractor for $3 and a small carbide drill bit (5/16?). You drill the tops of the damaged screws with the drillbit just a little bit. Then, you reverse drill out the screws with the extractor.
http://www.grainger.com/Grainger/CHICAGOLATROBE-Screw-Extractor-1U216?cm_mmc=Google%20Base-_-Machining-_-Machining%20Supplies-_-1U216
Yes just need a supplier in the uk. I have a large set of those for my Land Rover etc, didn't know they did them that small.
I have a nice low tech and cheap solution.
Get a thick rubber band and place it between the screwdriver and the screw head. Doesn't always work but has made my life easier a couple of times. :D
