alexsmith2709
- UK
I upgraded this PC to windows 11 to have some familiarity with it and occasionally it would be nice to use some remote desktop software for me to access while i am at home. I have tried using nomachine, teamviewer and anydesk and none of them connect. I have nomachine still installed and i can connect to other computers fine (although this is the only one running windows 11), but this one will not work as the server. I get a session could not be negotiated error. This happens both locally and externally. I tried switching to use a private key instead of password authentication and got the same error.
It doesnt appear to be a port issue as if the port is blocked/incorrect it doesnt even get that far, which is obviously expected behaviour. Windows firewall doesnt look to be blocking it, rules are there to allow the software through. Nomachine doesnt currently list windows 11 on their website, but Teamviewer has said it is fully compatible with Windows 11 so im guessing it is some setting on my computer/network that is causing this. Does anyone have any other ideas of where i can look? This may be a case of im over looking something very simple while trying to find something more complicated.
I have no other antivirus software installed other than windows defender which doesnt appear to be blocking anything, no firewall software other than windows firewall. I tried with UPnP enabled on my router to see if that was causing any issue, but i have the same problem. Quick Assist works, but is not ideal in this situation as unattended access is preferred as well as not having a disconnect because of inactivity.
Any ideas?
Any ideas?
