LongIslandTech
Hello fellow tech people. I have an issue that I dont quite know the answer.
Here is what happened:
Server 2008 R2 Raid 5. 4 Drives. Two amber drives. (Crap!)
No backups (Clients choice) (Even bigger crap!)
We tried everything... drives didn't go green. We took a shot and forced a drive online. It went green and was successful. The raid now said "Degraded". The 2nd amber drive went green and rebuilt.
Raid 5 says online. No issues.
Reboot the server. The server will not boot. It will only boot in recovery mode. I tried all the fixes. None worked. The server simply wont boot. bcd rebuild... everything. (btw the bcd rebuild sees the OS and I can say make it bootable but it simply wont boot) Fixboot fixmbr... everything. No chkdsk /r because thats a no no on a raid 5.
When I go into recovery mode and go to the command prompt I check diskpart. I see all the drive partitions. They all say they are healthy. When I cd to the drives I can see file structure. I see the directories ect.
So my question is:
If I do a reinstall of the OS do you think I will be able to access those other partitions and not lose the data? Obviously I wouldn't format the drive or re partition anything. I would just use the same partition that the OS is on now. What do you all think?
Thank you in advance. What a pickle....
So my question is:
