DocGreen
- South Bend, IN
Hey guys. I'm planning out a fiber backbone for this project I'm working on and I had a question that my Google-Fu couldn't answer. I've never actually learned how to terminate fiber, so we're using factory-terminated cables.
My question is, is there a limit to how many connections you can have on a fiber run? (by connections, I mean the little couplers that connect 2 terminated ends together)
Basically, I've got a 8 story building with a switch on every floor. I want to put an aggregation switch on the 1st FL, and then run fiber to each of the switches on the floor above. Can I link cables together from floor to floor without any trouble, or do I need to have a solid cable from the switch to each floor?
Ideally, I would do....
8-pair cable from 1-2
7-pair cable from 2-3
6-pair cable from 3-4
and so on, up to the roof.
Does that work? Or would having that many couplers on a single run cause too much signal loss? (It would be 16 couplers from the aggregation switch to the furthest switch)
