AlaDes
- White Sulphur Springs, WV
I have a laptop in for a Windows XP Pro SP3 OS repair. I have repaired almost everything wrong with it using D7, except two issues, but I think one is related to the other. The customer wants to refrain from doing a clean install if at all possible.
The main problem is that most of the program shortcuts will only open if you right click and select "open". Double clicking the icons or selecting them and pressing the "enter" key will not work. However, the programs work normally if you double click or select them and press the "enter" key on the actual executable itself.
The other problem is that if I run am running D7 and double click a shortcut or press the "enter" key after selecting it, the desktop foler opens up instead of the program associated to the shortcut running. Also, if I reboot the machine allowing D7 to run during boot time, the desktop folder opens as soon as the OS logs on.
One other problem I run into running D7's "KillEmAll" is that the DCOM crashes and shuts the system down within 60 seconds.
I am assuming this is a registry problem but have had no luck googling this problem in particular. Any and all help appreciated. Thanks.
