Valhalla_tech
- NC
Hey gang:
One of the things I've never been able to figure out in a in-depth manner, is creating an AIO solution for installing Windows. Basically, I like have a flash drive with all the viable versions of Windows on it (7,8.1,10, etc.) I've tried to create on using a combination of tools, WinAIO Maker Pro, NT Lite (for slipstreaming updates), and, of course, Rufus. However, I had no luck. I could only get the installation to recognize only one of the versions of Windows, even though all of the versions were saved to the ISO. Could be because I was trying to make it dual architecture, which I don't think is possible, but I'm not sure.
Anyhoo, I got my hands on a, ready made, 64 bit AIO, with the aforementioned Windows versions. When I tested it on a virtual machine, that I used VMWare Workstation to create, it loads the setup with a Windows 10 interface and installed fine. However, I'm on site, ATM, and tried to launch recovery console on a Windows 10 machine, and now it's loading the setup environment with Windows 7 interface, and, of course, won't launch the recovery console, because it's trying to launch the Windows 7 recovery console on a Windows 10 machine, which doesn't work.
I'm wondering, how do I determine what interface the setup launcher uses? Why would the Windows 10 environment load on my VM, but Windows 7 load on a physical machine? And, ideally, what is the best way to create my own AIO, so I can customize it. What are the best and/or easiest tools to use, etc.? Thanks to any and all suggestions, comments, and support, in advance.
Cheers,
Fred Smith
Valhalla Tech
Cheers,
Fred Smith
Valhalla Tech
