I had a customer call me about her PC not being able to access the internet. The PC is a Lenovo H520 desktop running 8.1. She said that her ISP (who she called first to see what the problem was) told her that the Ethernet has no valid IP configuration and that the Ethernet card need to be replaced (no Ethernet card, it's built in) or she should buy a new tower. So I go to her house to see if I can fix it there. I do a few things to see what worked, like resetting the router etc and nothing. So, not wanting to spend too much time there, I take it to my shop. I hook it up to my network and it still shows limited connectivity for the network. I run a virus scan to see if there is some malware blocking the connection. That didn't come up with anything. The next thing I did was ipconfig /release and then ipconfig /renew and when it finished the renew process it said that it could not connect to the dhcp server.
Next I run: netsh winsock reset catalog
netsh int ipv4 reset reset.log
netsh int ipv6 reset reset.log
And then rebooted the system. It connected to my network and I was able to access the internet unabated for two days and I rebooted the system many time to see just in case. It seemed to work just fine after that.
I take it back to her set it up all nice like and start it up and back to limited access again. So I reset the winsock, ipv4 and ipv6 again and BAM, back on the net. For now. lol. She calls me back today to say it was back to limited access. I think it may be the modem that she is connected to. Maybe changing the DHCP server setting? Should I set it to a static IP address? I told her to call her ISP to bring a new router/phone/modem out to her. What else could I try if the new modem doesn't work?
