Markverhyden
- Raleigh, NC
This only applies to OS X. Quick background. Updated a OS X server to 10.9. That went fine. As a precaution, of course, I shutdown all of the external drives attached to it before starting. Once I was done I powered them all up. Two drives, LaCie 2 Big-2 x 500gb-Concatenated Disk Set, did not show up. But all of the lights looked good. After troubleshooting it looks like both of the controllers died. USB shows nothing and Firewire shows an unformatted drive.
These are formatted via a switch selector on the back and was set to Big (Concatenated Disk Set) which is the default. By the way contents of the drives are identical. Started work on the first enclosure. Imaged both with R-Studio, build the array, and then start a scan. Of course this is taking forever since it's happening over USB2SATA.
Started playing around with the first pair of drives on my Retina and the drive with the boot sector shows up in disk utility but the second drive reports no partition. So I grab the second LaCie, pull the drives, hook them up to my Retina. Viola!!! Apple Disk Utility reads the RAID partition and the array mounts properly.
So if you have an HFS+ formatted external drive array that fails and it looks like there is nothing wrong with the drives themselves just try hooking them up to a Mac. If the OEM is not doing something sneaky like some of them with these special adapters that encrypt it should show up. Of course you need to make sure and image each drive before doing anything.
If you have a NTFS/FAT or Linux formatted partition the link below has instructions on how to get this done in those environments.
http://community.spiceworks.com/how_to/show/2399-recovering-data-from-a-lacie-storage-device
