HCHTech
- Pittsburgh, PA - USA
i've got a 25-employee architecture firm with a Dell Poweredge server from mid-2014. they currently have an HPE 1810 48-port gigabit switch and are running out of ports. I'd like to add a second switch and get one that would support a 10bgbs connection for the server.
The current switch has a couple of SPF connections, but they are only gigabit. The server is currently connected to one of the regular ports with a Cat5 line. One complication, the building is a big open space, no permanent internal walls and built on a concrete slab. the server is in the center of the space and the wiring closet is in the corner - about 60 feet away. Cabling between the two is through underground conduit.
I could use the existing cabling if I get a 10gb NIC with a copper connection for the server and find a switch with a couple of 10gb copper connections in additional the regular 1gb ports. If necessary, we could get someone to run a new Cat6 line through the conduit.
To use fibre, I would need a 10gb fibre NIC for the server, a switch with 10gb SPF ports in addition to the regular 1gb copper ports, and we'd need to find someone to run a fibre line through their underground conduit.
...I think. This is a little out of my normal experience - what would you do? Any particular switches to recommend that would hopefully be $1K or less?
