HCHTech
- Pittsburgh, PA - USA
It was bound to happen eventually, I found the one person that has loved and used OneNote since 2003.
This is a residential customer with a home-based business. I'm replacing her circa 2012 computer. She had Office 2010 (and 2003 on a previous computer). There are 1.5GB of OneNote files in hundreds of folders, organized under about 7 top-level folders.
So, I have multiple copies of the "live" OneNote files from the 2010 installation. The old computer still boots and runs fine, there is a local backup on an external hard drive, and an online backup on Backblaze. I also decided to make a backup from within the 2010 install of OneNote as that would probably be easier to restore into 2019.
Roadblock #1 - When trying to run a backup in OneNote 2010, "Some files were created in an older version of Onenote and cannot be backed up until converted". We won't tell you which ones they are, but if you open each folder individually, you'll get a prompt to upgrade. So, I grind through that job and get a set of 3 backup files, the file, a local cache and one other.
Roadblock #2 - OneNote 2019 will only use online files. There is no choice and the help file contains a link to a Microsoft note basically saying - "Tough luck - if this causes you to look for another solution, we understand." Ugh. I cannot find a way to restore the 2010 backup into 2019, but you can open a local file, which will give you an immediate prompt to upload it to OneDrive. So, make sure I'm logged into OneDrive with the same Microsoft Account used by OneNote 2019,I select the 7 top-level folders and agree to the upload. This takes you back to the main OneNote screen, and you can see the folders, but you can't view any content yet because it hasn't synced. Ok, time to wait.
Roadblock #3 - 2 hours later, none of the files are viewable yet, you just get the "hasn't synced yet" message in the window. No status bar, no percentage complete, just wait. 2 hours later, no change. If you look at the OneDrive folder, you can see 1kb shortcut files for the folders, and if you click on them, it opens a new tab in a browser to open the folder, but the message is "this file was created by another computer and hasn't finished syncing yet'. Four hours total and no evidence that there are any errors or any progress.
We have fast FIOS internet at the shop, so I don't think the problem is our internet connection - more likely a cap on how fast OneDrive will accept info - but I'm suspicious that it's not really working.
I'm close to installing OneNote 2010 on the damned computer and letting them continue to use it like before, but I know that's not the real solution.
Has anyone gone through a 2010 to 2019 conversion before that might have some guidance on the process?
