bigcuedaddy
- Redmond, Oregon
Long story, please bear with me
I was at a customer home to install additional RAM in their fully-operational PC. Obviously, pretty basic stuff. I powered down the PC, put in the RAM, and reconnected everything and tried to power back up. No powerup. Odd, so I made the obvious double-checks, even triple checks of connections, etc. No go. I prefer not to have PC components and test equipment scattered across a client's floor, so I said I would take it back to my bench and see what is going on.
I run voltage tests on the PSU, and get nothing back on any of the PSU pins on the multimeter. So I install a new PSU, and the unit fires up and all is well. Strange, but not impossible. I check to make sure the new RAM is recognized by Windows, and it is, so I reboot again to make sure the PSU and everything else is working properly, and all is good.
I take the unit back to the client, and power it up. No power! At this point, I am thinking there are gremlins in the client's UPS unit, so we run voltage tests through the multimeter, and all the UPS outlets check good at 120V. We check the power cable, checks good. We plug the PC into a totally different outlet, away from UPS, will not power up. Also, the client's router, modem, monitor and printer are all plugged into the UPS unit and are suffering no ill effects.
So as a last resort, and to satisfy my curiosity, we swap out PSU's from his Compaq in the back room (the one in question is an HP). Both are 24 pin, ATX12V, +P4 connector, should be compatible. No go. So I put the Compaq's PSU back in the Compaq, and now IT wont power up. Bizarre, at least to me.
I take both units back to the bench, and run more voltage tests, this time using a power supply tester. Although I realize they arent highly accurate, they at least will tell me if something is generally wrong. The original PSU that was in the client's computer to begin with now checks good. The new PSU I put in the client's computer checks good. The Compaq PSU we swapped out checks bad.
If it werent for the Compaq PSU going bad, I would be looking at checking the power switch to make sure it is working. However, with the system seemingly blowing the Compaq PSU, I have doubts the switch would be the culprit. At this point, in my mind it points to a bad MB, or at least something not connecting properly or shorted. Although probably not impossible, I have never come upon a situation where a motherboard would blow out a PSU.
I have discussed this nightmare with local tech friends, they have no suggestions. I have a hunch I am making an assumption or two in my troubleshooting that is not valid. My next semi-serious step is to bring in a priest and have the whole thing exorcised
Any sugestiions? What am I doing wrong?
