glricht
- Zephyrhills, Florida
Over the years, I've often looked at the number of active processes to get a feel on how a PC was functioning. If I saw a PC with a low-end chip, 4 GB of ram, but had 120+ active processes, it was almost a given that it was running a lot of software or needed to be cleaned up (e.g. infections, start-up list, etc.) -- or both.
Recently, I've noticed that PCs running Windows 10 Creator had a larger-than-I-expected number of active processes. Last week, I updated a Win 10 Anniversary with 85 processes to Win 10 Creator that resulted in 110 processes. Huh?
To see if I was imagining things, I dragged out an old test machine (Dell Optiplex 755, Core 2 Duo E6550 @ 2.3GHz and 4GB of memory) and tried to do an apples-to-apples comparison between Anniversary and Creator. The Win 10 install media used was from MS and didn't include any OEM-provided bloatware or security software. I tried to create two identical systems with the only difference being Anniversary and Creator.
First, nuked the HD and did a clean install of Win 10 Anniversary:
Then, nuked the HD and did a clean install of Win 10 Creator:
Anybody seen this?
- Setup a local account and made the settings the same as what I would use for a typical residential customer
- Used Snappy to update the drivers
- At this point, it was 1607 14939.0 and had 48 active processes at steady-state
- After applying all updates, it was 1607 14393.1480 and still had 48 active processes at steady-state
- Again, I setup a local account and made the settings the same as what I would use for a typical residential customer
- Again, I used Snappy to update the drivers
- At this point, it was 1703 15063.0 and had 118 processes at steady-state!
- After applying all updates, it was 1703 15063.483 and had 108 processes at steady-state.
Anybody seen this?
