[SOLVED] No speakers or headphones plugged in
alexsmith2709
UK
Hi,
Having a bit of an issue with a Dell XPS 13 laptop running windows 10 (17134 build). Customer said that a message about a disk error occured and since then, updates have stopped working and the audio no longer works.
I have checked the HDD and doesnt appear to be any problems. I ran sfc and no problems found. The audio service apparently didnt have permissions to start. Doesnt seem to be a restore point before the problem happened so tried a repair install and that seems to have fixed the permissions issue but now it says that "no speakers or headphones are plugged in". iTunes and windows media player both display an error when starting because of this.
I have plugged in external headphones and speakers to the headphone jack, it recognises they are plugged in, but still displays the error.
I have also tried rolling back and updating the audio drivers.
Windows update still doesnt work. It says it cannot connect to the update service.
Any other suggestions before wiping and starting again?
Hi Computer Bloke,
I just double checked (i was going by what was displayed in cmd) its 1803 build 17134.112 so not an insider preview.
I booted to a WinPE image i have and the audio was the same there so guessing hardware issue. An update though - The troubleshooter says the audio services are not responding and that the speakers/headphones are not plugged in.
Odd that windows update still doesnt work after a repair install so clearly some software issues too. I have run a windows update troubleshoot and reset with same results.
I have already used SDIO to update the drivers after completely uninstalling.
UPDATE: For those facing similar issues, it looks like i just fixed it by running these two commands:
net localgroup Administrators /add networkservice
and
net localgroup Administrators /add localservice
This appears to have fixed both audio and windows update problems
I searched the good land of google for "audio services are not responding" and came across those commands. After further research these commands had solved issues with other services not starting/responding and as i previously had issues with permissions for the audio service i thought it would be worth a try. Obviously i had a backup from before i started work on this laptop in case it went wrong.
...and did you sell the customer a shiny new SSD so he doesn't get the disk errors anymore?
It already had one and i could find no evidence of that error myself. The drive appeared to be in perfect condition, both from SMART checks and other scans/checks
(A small request: please don't use build numbers unless you're talking about non-production software; if you say your client is running Version 1803 then we'll all know what you mean. Anyway...)
Better run Win update. You are a few months behind in CU's.
Gotta disagree. Porthos' observation is why it is important to use the full build number. Some Cumulative Updates break things.
