Rob_NNCC
- Northern Neck of Virginia
First off, thank you for reading this!
I got called from a marine electronics shop to look at a Navistar 961X boat gps/navigation system. They would not work on it and as it turns out, it is a pc running NT. The system is pretty old, but would cost thousands to replace. It is a LT430TX Intel Motherboard, a 200MHZ P1, 32 MB ram, and a 3200 MB seagate harddrive. The system had some issues with posting, cleared up due to corrosion on the contacts of the ISA GPS card.
The issue I need help with is: NT. NT came out when I was in elementary school, and I am not even sure what version this is running. The system will not fully boot up. It loads the wall paper for the login screen then reboots. I have checked the generous amount of RAM
, it passed Memtest. I have checked the HDD, not corrupted. I have removed all the cards in the system and replaced the graphics card with a known working PCI ATI RAGE.
The boot splashscreen is replaced with loading... so I can not easily tell what version of NT, and I don't know what to check on the HDD manually. I did try to use autoruns to remove startup, it did not recognize the hives. Also, F8 did nothing for safemode. I read that some versions of NT do not have safemode.
The system bios battery also failed and reset the CMOS settings. I would like to know if that would make any difference as I don't think NT is a PnP OS, and if I need to reserve any IRQs or DMAs. (all the cards currently in the system are PnP, so the bios should handle that, but if they got changed from what they where before, would that mess NT up? (Again, legacy stuff that I have not had to work with in decades, stuff that I learned in elementary school...)
If anyone is willing to throw some NT advise at me it would be greatly appreciated!
