NAS Recomendation
johnrobert
Vancouver BC
I am looking to buy a reasonable priced nas that's easy to setup
They were asking for a server to host company files for about 5 users
I thought a nas would be better
synology for normal nas, qnap for nas where you want the nas to be running a VM for various apps/server purposes.
Edit: I know its unrelated to this thread but I just want to mention that some people have been purchasing qnap to run as a plex server, dont do it its not worth it. The nvidia shield tv is actually a very impressive plex server.
How come? I'm running a plex server just fine from my QNAP.
The transcoding capabilities with those celerons are not capable of doing 1080p with a decent bitrate, its fine for direct streaming but compared to the nvidia shield tv transcoding capabilities its pretty bad. If you got one of those really nice qnaps that can be upgraded or comes with an i5 or i7 then thats a different story.
Edit: I have the 453 pro
I install both Qnap and Synolgy regurarly and feel they're pretty solid platforms. If I want/need a powerhouse (for example for a Plex Server that can transcode) I build my own box using Openmediavault (free!) which is pretty fantastic if you ask me. You stay well below the price of a comparable off the shelf product.
Oh I love freenas. I have my FreeNAS box at my home. I thought about running ownCloud in a jail, but, I just prefer to FTP into it since I am the only one using it. I would use it as a shop backup but cannot find an opensource or free backup program that works with SFTP. Normal FTP is too insecure for my liken.
What @Slaters Kustum Machines said. Details like what types of files, etc.
Things like Intuit must reside on a real M$ filesystem share point. If the shares include that you should look at WD DX4000 series. Comes with M$ Storage Server. That also has backup services for M$ clients amongst other services. Not cheap but a great alternative to a standard server.
Otherwise I use Synology, FreeNAS, and ownCloud. All of them have multiple connection options as well as full support for all OS's.
mainly M$ office files and some Cad files
Everything on Google drive at the moment and their local computers
There are too many choices I usually do old farts break and fix I think I will go with Synology
one company I support has a Drobo it works great can be expensive after buying the disks
When I do support I think it's my own money I am spending
Two years ago I purchased a used QNAP TS-809 PRO NAS with 8 - 2Tb hard drives and earlier this year upgraded the 8 drives to 4Tb Nas drives. I use it for my movies in 1080P and have no problem with it... can have several people watching different movies at the same time, even with a remote connection. Comes with 2.8Ghz Core 2 duo cpu and my transfer speed writing to the unit from my personal computer is 90-110 MBps. Using Raid 6 ... got a decent system for once as I've lost too many movie storages over the years using home-built equipment
  • Like
Reactions: GTP
Should still struggle with 1080p with a decent bitrate for remote connection. Your processor is similar in performance to the one I have. As long as its not transcoding its fine but I only use plex for the whole remote thing with transcoding. For local usage I just use kodi.
That's the main reason I built my own box. DirectPlay is no option because my upload speed is rather limited. The E7400 in that Qnap has a passmark score of 1779. So DirectPlay would be fine but it would struggle with a 1080p transcode and that's why I chose an i5-4460 (passmark score 6598).
I based my choice on this Plex recommendation:
  • 1080p/10Mbps: 2000 PassMark
  • 720p/4Mbps: 1500 PassMark
For a few 100$ less than price of that QNAP I build my own NAS (Fractal Node 32, B85M-itx), including 5x4TB WD Red and a small OS drive, a better cpu and 8GB of RAM.
You do need to fiddle with the build and the software. It's bigger, has no hotswap-bays (and room for "only" 6 drives). It's a great project to work on if you have the time though.
Analyze your clients needs first....
Any accounting software that has to have a server component on a Windows OS?
You mention design software...will they grow into a need for having an organizer for it that runs on something like SQL?
Any need for centralized user and device management (Active Directory)
We do mostly Synology. Use good NAS/RAID rated hard drives, like WD Red editions.
Will they be working on the CAD files directly from the the NAS? If so, how many of the 5 machines use CAD?
CAD files can be huge and the program will crawl if the NAS/network can't keep up.
So far I think I would be considering a Synology DS416 with 4x drives in RAID10. And if they have a manged switch setup link aggregation. Of course you probably have a budget to go by, so I may be well off.
It's really not that surprising that people don't have reliable storage systems. But let's face it, as technicians there really is a lot of junk being sold to the masses that isn't worth putting in a bag to take home. One thing I like to recommend is that when considering a storage system, take the time to look at more than just "who made it". Namebrands are just that, the name of a brand. It is better to really research what is reliable to other people, and do not just get your information from 1 or 2 sites. Instead analyze a compendium of information and reviews.
When I was buying my first cdwriter I researched it a lot, and read fantastic reviews, and purchased a highly recommended unit reviewed favorably by a major computer hardware magazine. It was junk. I would also caution you, such that when you look at a unit, consider getting the manual, or a copy of it from the web as a pdf. Learn about the interior system and chipset, and research those. Also research what the best file storage system is for your needs? ext3? ext4? zfs? Maybe read about the differences of each one on wikipedia.
For Home storage or small business settings I recommend naslite by server elements. For larger organizations obviously servers or specially built nas systems.
