I've benn running into alot of Maxtor drives that have been failing recently. All of them recently have a common denominator, which is the manufacturer.
Gateway 500 SE systems, and all are Black/Silver towers purchased in or around 2002.
I've run into two versions of HD. Maxtor 20 GB 5400 RPM, model # 2F020J0 and Maxtor 40 GB 5400 RPM Model # 2F040J0.
Doing a search on these Models will pop up alot of "Hard Drive Recovery Services".
Anyways, when these FAIL, or start failing SMART does not work so it can fail without the end user being notified of any problems previously. All of drives will get corrupt sectors and overheat, and give a TEMP 253 OVERHEAT on diagnostics.
The quick and easy way to diagnosis this is using the Seagate Seatools from the manufacturer website here:
seagate.com/www/en-us/support/downloads/seatools
Some of the signs of the drive failing are: Slow accessing data, and boot sector corruption causing OS Loop on boot.
