arrow_runner
- Cincinnati, OH
I had a macbook pro come in with a cracked screen (15.4 LED). You could see that the spinning wheel would run for a little bit and then freeze on the screen. I booted up with a Linux CD and found that the screen would freeze if put into high resolution. (I'm pretty sure I've seen this with cracked screens before.)
Anyhow, I got the okay to replace the LCD and I put it back together and it worked perfectly.
The customer picked it up and apparently after a few hours of use he saw some artifacts on the screen and then it froze.(Same thing that happened before, he said) Now it's doing the same thing as before. (Stopping at the spinning wheel.) I'm pretty sure that the OS is loading fine, just the screen isn't updating.
I'm beginning to think that's it's a possible GPU issue, but I'm not sure. I'd like to get the system to boot into 'low resolution mode', but aside from booting into the command prompt, that's not working.
'Safe mode' also freezes btw.
Edit: Also should mention that the HD passed a SMART test.
