hmig89
- Sittingbourne, Kent
Hi guys,
Got a friend who's asked for a bit of help. His macbook does not go past a grey screen, I know where are a number of ways to troubleshoot this, however my main priority is to get the data off the current drive and back it up to a portable HDD. From what I understand if I turn on the macbook and insert the OS X disc I have (newer version that running os) and hold down the C button I can boot up with some tools available. (apparently this can also be done holding D depending when the macbook was built, I maybe wrong as its been a long morning)
What I want to know is when I enter the bootable area, I know I can run disk utility. If i create a back up from disk utility will it copy everything as if it were a clone? the apple site states it will produce a disk image of your entire Mac OS X disk's contents. If they grey screen is actually caused by something on the HDD will I still be able to access the data after backing up?
In the bootable area can I browse the current HDD and just take the files I need. Ideally I would like to grab everything and put that on a new drive.
I know you guys may need more info so please ask, apologies if I have not provided enough information, not very experienced with macs. Would appreciate your help.
