nlinecomputers
- Midland TX
Ok, I do not normally handle Macs. But one of my clients has an iMac Retina 2017 that he really doesn't even use that he suddenly got a bug up his butt about using it and powered it up for the first time in months. It was still on High Sierra and he wanted it updated to whatever was the latest MacOS.
He tried to do it himself and couldn't figure out how. It kept prompting him to upgrade to Mojave which for unknown reasons would not work. He had an external drive attached to it but he said he read that upgrading would wipe out that drive(I don't know the source of that and I didn't push it.) so he ran to Best Buy and purchased a new WD EasyStore WDBAJN0020BBK-XA, its a 2TB spinner, which the Mac would not mount. He said it was formated for Mac but the specs I read says it's an NTFS formatted drive. But Windows would also not see the drive.
I attached it back to the mac and kept getting code 8 errors trying to mount it. I downloaded the Mac version of WD Diag which says the drive is OK. It had a erase function so I let it reformat it. After that, I was able to mount the drive and point Time Machine to it. Time Machine did its backup successfully so I upgraded the Mac to Big Sur. After the upgrade, his copy of Webroot complained that it was not compatible and needed to update. I updated it, let do the scan it was insisting it needed to do, and went to bed. This morning I find that Time Machine has errored out with a code 8. The drive can be mounted but running first aid results in a code 8. WD Diag is running on it now but I suspect that it will again come clean. So what is going on here? Is there anything known to mess up Time Machine? Webroot a problem? Or is it just a bad drive?
