M$ won't accept a product key
  • Thread starter Thread starter Coffee is good :)
  • Start date Start date
C
Coffee is good :)
Guest
I torrented an unbranded/unchanged copy of
Windows XP Home OEM SP3
- I have to use it to reinstall XP on a new HDD
. The product key is for XP Home OEM SP2 < does SP matter?
Product Name : Windows XP Home Edition
Product ID : 76477-OEM-yadda
Product Key : MK48G-lalala
Installation Folder : C:\WINDOWS
Service Pack : Service Pack 2
Computer Name : SYSTEM
Modified Time : 7/22/2010 10:44:18 PM
JAY: "OEM versions of vista pre installed by HP, Del and others will have two keys. The key that software like Produkey (that's what I used!) find is the OEM SLP (System-Locked Pre-installation) key linked to the motherboard. But OEMs are required to also include a valid COA license with sticker. It is this product key you must use when doing a reinstall of vista not the one your software shows as it will never activate."
http://www.technibble.com/forums/showthread.php?t=17808&highlight=microsoft+product
Alan22: "Many years ago Microsoft stopped allowing Branded OEM license keys from activating Windows installations via the Internet. People were going to retail stores, writing down OEM license keys from the COA sticker and using them to pirate copies of Windows, whether on their own single system or on multiple systems. This is just one of Microsoft's efforts to combat piracy. In some cases the Branded license keys can't even be used to install the OS.
So, the COA found on Branded OEM COA's should not work to activate Windows via the Internet, especially if not using the correct, Branded OEM Windows installation disc. To properly reinstall Windows on a Branded OEM computer system the manufacturer's installation disc should be used (i.e., Dell for Dell, HP for HP, etc.). These Branded OEM Windows installation discs should be pre-activated and should not require the end user to perform any type of activation. Plus, the EULA's are different from regular OEM, upgrade and full retail EULA's.
I've installed Windows I don't know how many hundreds of times over the years and I always use the correct Branded disc for the computer I'm working on. I've never once had to activate Windows in this scenario. In addition, I've also performed hundreds of upgrades and fresh installs via regular OEM, upgrade and full retail discs. In each case those needed to be activated either by Internet or phone. Some didn't activate over the Internet, but a call to the activation center results in obtaining an activation code. You first need to go through the automated phone process, then when it fails you're transferred to a live person who can provide an activation key (after answering some questions)."
I discovered that the Certificate of Authenticity shows a different product key than what was given by ProduKey.
Here's what I'd do the next time a hard drive is failing:
- Try to create an image of the drive to reinstall on a new drive. If that doesn't work -> try to copy the recovery partition to the new hard drive to install Windows (and backup data ALWAYS).
If that doesn't work and no recovery discs are available ->
Install Windows using an unbranded version of Windows (OEM in most cases).
If need be, torrent it and make sure it matches the MD5s that are somewhere in this forum. Make sure it's unbranded and has had absolutely no changes made to it (no cracks or tweaks etc).
ONLY install this if the COA can be located. Also, make sure to run ProduKey to get the other product key JUST IN CASE.
If COA can't be found, then buy the recovery discs from the manufacturer or from here: http://www.restoredisks.com/?gclid=COGV7ojVxZ8CFQfxDAodYnqA3A
SUCCESS !!
I got Windows to accept the product key by using an unbranded, torrented copy of Windows XP Home OEM with the Certificate of Authenticity key. Connected the computer to the Internet then activated and it did it without me having to call Microsoft.
