Linux On Older Computers For new Users
ComputerHoundUK
Lincolnshire UK
Over the last couple of years I have been installing Linux (Mint mainly) on client systems that are just not going to run Windows 11.
Most of these systems are quite old laptops (only a few desktops) which can't upgrade or the owner has insufficient funds to upgrade.
They can be up to 12 years old, so quite old 'n slow, but functional.
So, depending on the state of the system and what the owner uses the system for etc, I sometimes try and convince then to try Linux.
I usually back-up any User Data and then remove the original HDD and install a suitable SSD. Mind you these are getting expensive!
I'll install Linux Mint, Cinnamon if the hardware is OK to run that or Xfce if the hardware is really low spec!
After some tinkering, I usually end up with a system that boots and runs fine and nearly always meets the client's needs, which are usually quite basic web browsing, emailing etc, all done via the GUI when possible, these are new Linux users who will probably glaze over if I try and get them to use a Terminal!!
Not had any clients that have used Linux before, so I give them a basic lesson so they can get the hang of it.
I also put some 'Help with Linux' type documents on the installation for them to read, if they want to.
Below is one of the documents, which I’ve tried to condense into a couple of A4 pages. Difficult, I know, when you're trying to describe a Linux system's main areas!
I was just wondering what people think of this document, which is really aimed at new (possibly 'oldish' as most of my clients seem to be).
Is there any glaring errors or anything else I should include or leave out?
Thanks!
Quick Start Linux Mint (Cinnamon Desktop)June 2026
What Is Linux?
Linux is a free, open-source, Unix-like operating system (OS) based on the Linux kernel, originally created by Linus Torvalds in 1991. It is widely used for computers, servers, mainframes, and mobile devices, known for its security, stability, and flexibility. It is typically distributed as a "distribution" (distro) containing the kernel, system utilities, and a GUI.
Turn On Linux Mint:
Just press the PC / Laptop power button and Linux will boot up in to the Logon Screen, where you can enter your User Account password.
Password:
Account passwords in Linux are essential for security, acting as the primary barrier against unauthorized system access and protecting sensitive files.
NB: it is possible to remove the need to enter your account password so the system will log straight into the Desktop Environment. However, there will still be other times when the system will ask you for the password, such as most system Updates.
The Desktop:
What you see after logging into Linux. The Linux Desktop Environment (DE) provides you with user friendly environment for interacting with your PC. There are several different DEs available, the one I use in Linux Mint is called the Cinnamon Desktop.
The Mint Start Menu:
The Linux Mint (Cinnamon) start menu is a highly customizable, categorized application launcher located in the bottom-left corner. It features a left-hand "Favourites" bar, a central application search/list, and category filtering. Key features include drag-and-drop pinning, search functionality, and easy access to system settings, file manager, and power options.
Applications:
There are many useful built-in applications (apps) included in Linux Mint. Should you need them, there are many more available for download and installation from the ‘Software Manager’ utility.
The ‘Linux Mint Web App Manager’ is a tool that allows you to turn any website into a stand-alone desktop application.
AppImage apps – a universal packaging format for Linux that allows developers to distribute applications as a single, portable executable file. Download the .AppImage file from a trusted software developer or browse directories like AppImageHub.com
File Management System:
The default file manager in Linux Mint (Cinnamon edition) is ‘Nemo’, a fast, stable, and feature-rich application based on GNOME Files (Nautilus). It provides a traditional desktop interface with tabbed browsing, split views, a sidebar for bookmarks, and powerful search capabilities, allowing for efficient file management.
User Data:
Linux Mint stores all user data—documents, downloads, desktop settings, and application configurations—within the /home/[username] directory. This folder is separate from system files, ensuring user data is safe during updates and allowing easy backup or migration. It includes hidden files (e.g. local) for personalized application settings.
Links:
To Apps, Folders & Files On The Desktop Linux Mint allows creating desktop links for files, folders, and websites for quick access. You can create symbolic links (symlinks) to folders via the File Manager (Nemo) by selecting "Make Link", or create web app links via the Menu. Web apps automatically add "HTTP," while desktop links can be customized with icons and renamed.
Connecting to a Network:
Connecting to a network in Linux Mint is primarily managed via the network applet in the bottom-right system tray. Left-click the network icon (arrows for Wi-Fi, computer screen for wired) to select a Wi-Fi network, enter credentials, or manage wired connections. Network Manager automatically handles DHCP and saves credentials.
Security:
Linux Mint is considered highly secure out-of-the-box, leveraging robust Linux architecture, built-in firewalling (UFW), and secure software repositories. Security is strengthened through system snapshots (Timeshift), mandatory user password permissions (sudo), encryption options during installation, and infrequent exposure to malware, making it ideal for standard desktop, laptop, or professional use.
Browser(s):
Linux Mint comes with Firefox pre-installed as the default web browser, offering a secure, open-source browsing experience out of the box. Users can easily install alternatives via the Software Manager, including Chromium (supported by Mint), Brave, Vivaldi, Opera, and Google Chrome. These options allow balancing privacy, performance, and compatibility.
Email:
Linux Mint primarily uses ‘Mozilla Thunderbird’ as its default, pre-installed email client, providing a robust, open-source desktop application for managing multiple accounts (Gmail, Outlook, etc.), calendars, and tasks. It offers extensive customization, local storage for privacy, and native desktop notifications.
Office:
LibreOffice is a free, open-source, and private office productivity suite. It provides a powerful, offline alternative to Microsoft Office, featuring applications for word processing (Writer), spreadsheets (Calc), presentations (Impress), and more.
Printing:
Linux Mint offers excellent, often driverless, support for scanners and printers, typically detecting them automatically via IPP or SANE protocols. Printer management is handled via CUPS, accessible in system settings, while scanning is best managed through "Document Scanner" (Simple Scan).
Updating Linux Mint:
The Linux Mint Update Manager (mintUpdate) is a secure, user-friendly tool that centralizes system updates, including software packages, security patches, Flatpaks, and kernel updates. Located in the system tray, it categorizes updates for safety, allows configuration of automatic updates.
File System Structure:
Linux Mint uses a hierarchical, tree-like file system, starting at the root directory (/), designed for security and organization. Unlike Windows, it treats all hardware and files as files within this single tree, with home folders in /home, configuration in /etc, and binary files in /bin. The standard, recommended file format is ext4.
The Kernel:
The core interface between a computer's hardware and its software processes. It acts as a mediator, managing system resources like the CPU, memory, and storage to ensure applications can function efficiently and safely.
The Shell:
The Linux Mint shell, typically Bash (Bourne Again Shell). It is used for system administration, software installation, file management, and automation, often serving as a faster alternative to the graphical interface.
Users:
Finally, we need to distinguish between two major user types. There's the system administrator user, called root, with the identified number 0 (ID=0). Then, there are regular users, with generic names.
It is a little confusing that the word root is used for three different things: the root of the filesystem tree, marked by slash (/), the root user, the system administrator user, and the root user home directory, found under /root.
Turn Off Linux Mint:
Open the Start Menu and use the red ‘Power Off’ icon.
It's great that you're repurposing older hardware for those with simple needs. The majority of my customers are seniors too but, to be honest, a document like this would go way over their heads.
I would just sit next to them and show them how to:
  • Turn it on
  • Use Firefox for web browsing
  • Use Thunderbird for email
  • Use LibreOffice for docs, sheets and presentations
  • Shut it down
Then get them to do it themselves and make their own notes if they feel the need.
If they needed anything more than that I'd be steering them towards a Windows 11 machine.
Thanks for your thoughts!
Yep, I think I may have gotten a little carried away with it. Or am overestimating some of my clients abilities, he he!
I would have to agree with @seashore . I've never used Linux so you lost me after the second definition. I live in a retirement town and a lot of my customers barely know how to use Windows. Most just want to go online and pay bills, check their bank accounts, etc. They would become frustrated learning something new so, if I were to become familiar with Linux enough to sell it, I would have to dumb down a lot of instructions, in order to sell a customer on its use.
I had my first Linux customer a couple days ago but had to send him to someone else, because I don't know Linux. Looks like I might have to learn, however, since I don't like sending anyone away.
... Looks like I might have to learn ...
Maybe 12 to 15 years ago I had a need to recover data from some client's failing hard drive. I installed Linux Mint on an old desktop so I could try the DDRescue application. I've kept a Mint machine in my lab ever since.
I won't say it's easy but it's also not very difficult for someone like us who understand the basics of computing and OS'es.
With the advent of AI-empowered browsers it's become very simple to get questions answered without having to wade into the toxicity of places like Reddit.
I just built a newer Mint machine and my biggest problem was trying to remember my Firefox profile password.
I'm sure I'd have no problem learning it but I've been holding back so long, since Windows is easy for me, after working with it for so many years. I'm 70..... do I really WANT to learn something new, when I'm so comfortable where I'm at? lol
This is exactly what most techs don't account for, in any significant way, when they say, "Oh, {operating system X} is easy!" No, it's not. No operating system is easy. No operating system is "intuitive" (a word, when I hear it applied in computing, makes me want to throttle the person saying it).
It takes each individual years to develop the skill set and knowledge they have on the OSes they use, and where those skills become as fluid as breathing. They were not that way to start.
This is most easily demonstrated by handing "your average user" an iPhone if they're accustomed to Android or vice versa. No matter how strong the similarities are, it is those teeny, tiny differences in all those things that have become "like breathing" and where they occur automatically from years of practice that drive people insane (or to want to throw the device across the room or into the trash).
I was actually a C programmer on several Unix variants for almost a decade in the 1990s, I can use Linux pretty darned well (though when it comes to the CLI I'm very rusty), but I wouldn't think of springing Linux on any long term Windows user who does not make that decision to go that route for themselves. Seniors in particular. Not only do I think it makes life exceedingly difficult where it need not be, but I don't have the time to become their resident Linux go-to expert.
Stick with what your client is comfortable with unless no other option exists. When it comes to Windows 11 hardware that's way more than capable of what most home users will use it for, it's out there and it's cheap and it works. I've been moving my residential clients to Chinese made NUC-equivalents when cost is a factor and have only had problems with one, and the company, GMKTek, has provided better technical support and warranty support than any major manufacturer I've dealt with over decades.
@britechguy , I'm with you 100% on sticking with what I know. I don't do any phone stuff but, every once in awhile I can help with an Android. I'm totally lost with iPhones, iPads, and ALL Apple products. I send those people to my son, who does it all..... [except Linux]. I've worked with Macs in the past and dual systems where Boot Camp divided the drive between Apple and Windows but I didn't like the Mac at all. I'll stick with what I know best.
Thanks for the replies, things to think about and always good to learn from others experiences & wisdom!
However, I have found most of my clients (ones that are open to the idea, anyway), so far, to be quite receptive, when shown, how they can survive a transition to the world of Linux.
Once they get over the different look of the new OS and start to see things that they recognise, such as Chrome, LibreOffice and Thunderbird and that the usage of those applications is the same as it is on a Windows based system, they are mostly fine with it.
I've only met one client, so far that needed some kind of application that was/is simply only available on Windows and they were not open to the idea of trying some kind of alternative.
I'm not talking about the masses here, only a small section of my own client base here in Lincolnshire UK, so results will vary a great deal, no doubt!
Bit, given the right encouragement and instruction, these clients (mainly seniors too) have started using Linux successfully for their needs, which, admittedly, are usually quite mundane, but, nevertheless, very important to them!
Yes, I do get questions about "How do I........?" But I get questions about "How do I....?" on Windows also, always have.
I don't mind questions, at least it shows that they are slightly interested! Maybe it's the ones that don't ask any questions, that I should be worried about!
I do try and give them more information in the form of the above document and a good list of web-links to very helpful online resources, so they can, if interested, learn a little more for themselves. How many actually do that, I don't know, but it's there, as I am too.
Another large factor is that it is saving them money also, they seem to appreciate that around here and in the current financial climate etc.
Now, i'm just a one man business and only part time at that. This is not my main source of income, more a case of I just love doing it! So i'm not really looking at this as a major revenue generating scheme, more a way of trying to help out some of my clients keep on using their systems securely and as safely as possible especially due to the demise of Windows 10 meaning that their still working oldish systems are fine to use for a few more years yet. Yes, eventually they may need to invest in something a bit more modern and I do advise them of that, but they seem to appreciate being given more time to think about doing that.
Also try to educate/remind clients the importance of backing up their user data, even when using a different OS.
I do also have clients that refuse to entertain the idea of switching to a different OS and are quite happy to pay for new systems running Windows 11 and that's fine by me also, keeps me in doing 'setting up & transferring data' type jobs.
This could lead to another topic about some of the 'characters' encountered on jobs, blimey!
Just my experience and thoughts from a corner of deepest Lincolnshire.
Let's not forget the little o'l lady and Linux. ...chuckles....
Give Zorin a spin. I got a customer who will not move to W11 from W10. So he's wants to have Linux and W10. W10 with be "air gapped" so to speak. He'll use the Linux side to get email, cloud downloads, etc and move those to the W10 side using a shared drive. Zorin has a free version and a paid version which he'll use. Like 50-60 USD. You can choose different themes based on Windows versions with the paid version. Haven't really dug into it though. Having been a Linux user for some 30 years, as the saying goes, they all look the same to me.
Just curious if he's stated his rationale? Windows 11 was nothing more than a "rebranding effort" as Windows 11 started out life as a planned feature update for Windows 10, and the core ID is still 10.
I am always really curious why anyone who is a Windows 10 user would adamantly refuse to move to Windows 11. It's always been irrational, in my experience, but even knowing why allows me to think about things I might say to those who are hesitant, but not adamant.
Curious have you tried CachyOS? As it would be even easier for clients transitioning as is more "Windows" themed. As for clients transitioning for general use - email, youtube, social media etc would be a great alternative. Personally I use Linux Mint, though do have a Live Version of Cachy on my Ventoy. Cachy allows Boot Selection with the UEFI + GRUB bootloader, it is a rather clean and easy to use environment, even has a GUI install menu system as well.
Personally it would be quite a headache transistioning clients to Linux, depending on customers own knowledge. Some are fantastic others not so, so one sighs and internally dies. Do you have the customers contantly emailing, texting etc " I have no idea, how to x and y"? I think a better idea is that one would need to supply the client with some documentation or quick guide to assist them. Looks like something I may do in future depending on request.
