Last set of updates+malware=bsod
Galdorf
Ontario, Canada
I have tracked down problems with last set of updates and malware causes bsod loops i have had over 20 customers show up with this problem, what i did was system restore before the updates clean the machine and re-apply.
Although i made quite a bit of money fixing these problems this could cause massive problems on global scale due to the amount of malware out there.
I've seen something similar to this on XP. Specifically related to NTOSKRNL. Basically what happened was Malware made some low level changes, then a major update came along that also made low level changes, causing severe conflicts.
I had to use a bootable disc to roll back the updates, then clean the system, then re-apply updates.
