Laptop screw stuck
joydivision
Manchester, UK
I need to get a scew out of this laptop, it keeps freezing and I suspect its faulty RAM. Some plonk has put the wrong screws in everywhere and one of them won't shift.
Anything I can try before I start drilling it out? I've tried using a straight screw driver etc with no luck. The screw is recessed so there is no way of gripping the head other than using a screwdriver :(
I have had success with a small star driver. Sometimes they will grip it and get it out. Otherwise you want to take a drill bit that will take off the head of the screw and then when you get it opened up take a pair of pliers and remove it by force.
Good luck
I can't get to the screw its buried deep, you know what I mean :).;
Already tried the star screw drivers etc. I am a bit nervous about taking a big drill to a laptop, never done it before.
Drilled it out, but its not the RAM causing it :(
Just testing the HD now, I hope it is not that, as I already have another one of his laptops on my desk needing a new HD, waiting for HP to send the CDs for it.
Seems to be BSOD on a completly different thing each time, so it is looking like it may be a motherboard fault.
Run Linux Mint/other live cd & see how things go; If that is successful, I would suspect the hd.
I had a recent laptop that was giving different blue screens randomly - diagnosis - bad hard drive. Replaced and all is good.
EDIT - test the CMOS batt voltage - I've seen low voltage cause strange errors...
concerning the screw that is stuck:
Take a small cheap screw driver and a file. File it down to "Fit" a similar type screw. Use it to get it out.
OTHERWISE:
Look into getting a set of "Easy Outs" These are basically reverse thread screws in the fashion of a drill bit. Very easy to use but dont use them in a drill. Do it by hand.
http://www.toolprice.com/category/screwextractors/
This is what you get the big bucks for!:D
