coffee
- United States
Got a fun one in. Customer has a Lexar 8 gig jump drive (flash stick). The stick is non responsive. There is some melting on the outer plastic case where the usb connector is. My thinking on this is that for whatever reason the controller chip overheated and died. What I am thinking of doing is getting another identical Lexar 8 gig and do a memory transfer. Either that or do a controller transfer. However I have a 16 gig Lexar that I thought I would experiment with first.
First thought - Can a 16 gig stick be used instead for a donor stick? Well, Biggest difference is that instead of one Nand chip (8gig) it has two. One on each side. So, Thought is - Can it function with just one stick on it and report just 8 gigs instead of the original 16? So, I removed the mem chip from the underside and plugged it in. Nope. Didnt like that. We come up with some errors in addressing the stick - lol. But the looks of the jump drive is exactly the same.
Now my thinking is, The controller may be programmed for 16 gigs either firmware wise or its just hardware compatible with 16 only.
As for the original jump drive from the customer all the supporting components on it test fine. There are no burn spots of any kind or other indications of letting the magic smoke out. So, It comes down to either the Nand is bad or the controller. Since the melting plastic is where the controller is in relation to the packaging I think its fair to say the controller has gone south on this.
So, Anyone venture into this territory? I will be experimenting a bit further with this 16 gig chip and might break out another 8 gigger to screw with.
Thoughts anyone ? I do see some Nand chip readers but they are going to be way out of my price range.
coffee
coffee
