Yes.
I deleted the </body> and </html> at the bottom of the sql file?
Found it.
Near the bottom.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en" dir="ltr">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<link rel="icon" href="./favicon.ico" type="image/x-icon" />
<link rel="shortcut icon" href="./favicon.ico" type="image/x-icon" />
<title>phpMyAdmin</title>
<link rel="stylesheet" type="text/css" href="phpmyadmin.css.php?server=1&token=7a88f2f3f56b1d30447f945338c31a87&js_frame=right&nocache=5406696958" />
<link rel="stylesheet" type="text/css" href="print.css" media="print" />
<link rel="stylesheet" type="text/css" href="./themes/pmahomme/jquery/jquery-ui-1.8.custom.css" />
<meta name="robots" content="noindex,nofollow" />
<script src="./js/cross_framing_protection.js?ts=1344778698" type="text/javascript"></script>
<script src="./js/jquery/jquery-1.4.4.js?ts=1344778698" type="text/javascript"></script>
<script src="./js/update-location.js?ts=1344778698" type="text/javascript"></script>
<script src="./js/config.js?ts=1344778698" type="text/javascript"></script>
<script src="./js/functions.js?ts=1344778698" type="text/javascript"></script>
<script src="./js/jquery/jquery.qtip-1.0.0.min.js?ts=1344778698" type="text/javascript"></script>
<script src="./js/messages.php?lang=en&db=rawling4_mvrail&token=7a88f2f3f56b1d30447f945338c31a87" type="text/javascript"></script>
<script type="text/javascript">
// <![CDATA[
// Updates the title of the frameset if possible (ns4 does not allow this)
if (typeof(parent.document) != 'undefined' && typeof(parent.document) != 'unknown'
&& typeof(parent.document.title) == 'string') {
parent.document.title = 'box596.bluehost.com / localhost / rawling4_mvrail / jos_jstats_page_request_c | phpMyAdmin 3.4.11.1';
</script>
<meta name="OBGZip" content="true" />
<!--[if IE 6]>
<style type="text/css">
/* <![CDATA[ */
html {
overflow-y: scroll;
</style>
<![endif]-->
</head>
<body>
<div id="prefs_autoload" class="notice" style="display:none">
<form action="prefs_manage.php" method="post">
<input type="hidden" name="token" value="7a88f2f3f56b1d30447f945338c31a87" />
<input type="hidden" name="json" value="" />
<input type="hidden" name="submit_import" value="1" />
<input type="hidden" name="return_url" value="export.php?" />
Your browser has phpMyAdmin configuration for this domain. Would you like to import it for current session? <br />
<a href="#yes">Yes</a> / <a href="#no">No</a>
</form>
</div>
<div id="serverinfo">
<a href="main.php?token=7a88f2f3f56b1d30447f945338c31a87" class="item"> <img class="icon" src="./themes/pmahomme/img/s_host.png" width="16" height="16" alt="" />
localhost</a>
<span class="separator"><img class="icon" src="./themes/pmahomme/img/item_ltr.png" width="5" height="9" alt="-" /></span>
<a href="db_structure.php?db=rawling4_mvrail&token=7a88f2f3f56b1d30447f945338c31a87" class="item"> <img class="icon" src="./themes/pmahomme/img/s_db.png" width="16" height="16" alt="" />
rawling4_mvrail</a>
<a href="sql.php?db=rawling4_mvrail&table=jos_jstats_page_request_c&token=7a88f2f3f56b1d30447f945338c31a87" class="item"> <img class="icon" src="./themes/pmahomme/img/s_tbl.png" width="16" height="16" alt="" />
jos_jstats_page_request_c</a>
</div>
<!-- PMA-SQL-ERROR -->
<div class="error"><h1>Error</h1>
<p><strong>SQL query:</strong>
<a href="tbl_sql.php?sql_query=SHOW+TABLE+STATUS+FROM+%60rawling4_mvrail%60+LIKE+%27jos_jstats_page_request_c%27&show_query=1&db=rawling4_mvrail&table=jos_jstats_page_request_c&token=7a88f2f3f56b1d30447f945338c31a87"><span class="nowrap"><img src="./themes/pmahomme/img/b_edit.png" title="Edit" alt="Edit" class="icon" width="16" height="16" /> Edit</span></a> </p>
<p>
<span class="syntax"><span class="inner_sql"><a href="./url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fen%2Fshow.html&token=7a88f2f3f56b1d30447f945338c31a87" target="mysql_doc"><span class="syntax_alpha syntax_alpha_reservedWord">SHOW</span></a> <span class="syntax_alpha syntax_alpha_reservedWord">TABLE</span> <span class="syntax_alpha syntax_alpha_reservedWord">STATUS</span> <span class="syntax_alpha syntax_alpha_reservedWord">FROM</span> <span class="syntax_quote syntax_quote_backtick">`rawling4_mvrail`</span> <span class="syntax_alpha syntax_alpha_reservedWord">LIKE</span> <span class="syntax_quote syntax_quote_single">'jos_jstats_page_request_c'</span></span></span>
</p>
<p>
<strong>MySQL said: </strong><a href="./url.php?url=http%3A%2F%2Fdev.mysql.com%2Fdoc%2Frefman%2F5.5%2Fen%2Ferror-messages-server.html&token=7a88f2f3f56b1d30447f945338c31a87" target="mysql_doc"><img class="icon" src="./themes/pmahomme/img/b_help.png" width="11" height="11" alt="Documentation" title="Documentation" /></a>
</p>
<code>
#2006 - MySQL server has gone away
</code><br />
</div><script type="text/javascript">
//<![CDATA[
$(document).ready(function(){
// updates current settings
if (window.parent.setAll) {
window.parent.setAll('en', 'utf8_general_ci', '1', 'rawling4_mvrail', 'jos_jstats_page_request_c', '7a88f2f3f56b1d30447f945338c31a87');
// set current db, table and sql query in the querywindow
if (window.parent.reload_querywindow) {
window.parent.reload_querywindow(
'rawling4_mvrail',
if (window.parent.frame_content) {
// reset content frame name, as querywindow needs to set a unique name
// before submitting form data, and navigation frame needs the original name
if (typeof(window.parent.frame_content.name) != 'undefined'
&& window.parent.frame_content.name != 'frame_content') {
window.parent.frame_content.name = 'frame_content';
if (typeof(window.parent.frame_content.id) != 'undefined'
&& window.parent.frame_content.id != 'frame_content') {
window.parent.frame_content.id = 'frame_content';
//window.parent.frame_content.setAttribute('name', 'frame_content');
//window.parent.frame_content.setAttribute('id', 'frame_content');
</script>
Do I just delete it?
I wonder if this guy knew what he was doing?
Regards,
