The computer is a VPR Matix, Series 210,Model Ft-4100:
System would not power on, The power switch would light up, But system would not power on when switch was pressed. Checked power supply with tester and it passed. Then removed power cord and reinserted the cord and turned the switch on the power supply on and off. Tried the power button and the system came back on with no problem.
So I continued to work with customer when the system "Froze" after about and hour of use.. I was running UBCD for windows and copying files from an external drive on USB to another external drive on USB. System would not reboot using Ctrl-Alt-Del sequence. Held down the power switch and the system turned off. Then systen would not power back on .Tried the same steps as menioned above with the power supply switches and system still would not power up. Could this be a power supply issue or maybe a MB issue ?
My next step is to try a new power supply. Thanlks for your help.
