ComputerClinic
Customer brings in iMac (this model)and says the screen goes black intermittently and can sometimes be restored by hitting power button twice (in and out of sleep). Letting it run idle for a few minutes reproduces the problem and shining a flashlight on the LCD reveals that video is still being sent but the backlights aren't on. Just to be sure this was a hardware problem I boot up to an ubuntu live CD and sure enough the screen goes black after a while.
My next step was an SMC reset, which made no difference. Since there was no flickering and this LCD has more than one backlight I assumed the inverter board is to blame. After replacing the inverter board I leave the PC on overnight w/ no issue. Everything seems OK so the PC is returned to the customer.
A few days later the customer calls back and says the problem remains. I am able to reproduce the problem w/ the new inverter board as well. I had a slightly different inverter board (ordered wrong part accidentally); the only difference being a different connector for the vertical-sync cable. I installed this board (leaving v-sync uplugged) and was able to reproduce the problem again.
So I doubt that 3 inverter boards have the same problem and now I'm thinking the LCD needs to be replaced. Does this sound like the most likely solution to you guys or am I missing something?
