I have searched the forums and found a little information about this, but it's all a few years old and I was hoping for some up-to-date advice. I am recently gaining more and more medium size clients (20+ stations) and I think I am in the market for a more robust network tester to help me troubleshoot some of their network issues. I want something I can plug into a potentially malfunctioning drop and get a readout as to how well the cable is working, what the problem is, where the problem lies etc...
I'll give an example: I have a potential client, a large church with 13 workstations, 2 servers, and un-documented cabling running all over the place. They have complaints of the network being spotty at some stations. DNS doesn't seem to work all the time, server access is intermittent. Is it the workstation or the network? I could swap in another workstation, but we would have to wait for a month to know if it is better or worse as it is so intermittent. Running cables would be expensive as the walls and floors in the place are all masonry with no real chases to lay wire, so I don't want to replace anything that isn't absolutely necessary. I would like to come in and plug the tool into each existing port and know that this port and cable is good or bad. Can it handle Gb or not, it isn't spliced or run too long or looped or run over a light etc... so I can either recommend to replace it or not.
I think the linkrunner LRAT-1000 from fluke will do this, but I want to know what I am missing by not having something like the 1t-1000. There is no way I can afford $10k right now for this tool, but $1k is an acceptable expense if it has the capabilities I need.
