HP Proliant will not use all of its RAM
Blue Banana
South Africa
Help me figure out what I'm doing wrong. HP Proliant ML150 G6. One CPU installed. We installed three of these modules:
https://memory.net/product/m393b1g7...1600-rdimm-pc3l-12800r-single-rank-x4-module/
When posting, the server displays invalid memory population message but contunes to boot into Windows Server 2008 R2. The system reports 24GB installed and 16GB usable. I tried a few different configs with the modules, taking one out, makes the system beep. Not sure why it's not working properly.
I read through the manual here: http://content.etilize.com/User-Manual/1015372387.pdf
As well as the memory config page here:
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c01810886
Unless I'm missing something totally obvious, I'm sot sure why not all the RAM is being used and the invalid memory message is displayed.
Maybe because it's a single CPU? Some add'l info here: http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c01715581&sp4ts.oid=3884323
"If only one processor is installed in a 2CPU system, only half of the DIMM slots are available"
There are two ranks of RAM slots, one for each CPU. I doubt this is what they mean. Previously there were 3x 4GB and 2x 2GB modules installed in this rank, mixed brands also.
mainboard-servidor-hp-proliant-ml150-g5-dl180-461511-001-D_NQ_NP_20313-MPE20188818033_102014-F.jpg
When you take the cover off an HP server, the inside of the cover will have a big diagram of the mobo, including showing you the order to populate the RAM.
Servers can be picky about this, and they're very specific with their RAM. I'd avoid mix-matching RAM, this isn't a desktop system. Get the exact RAM certified for this server and install it according to instrux.
Maybe I'm having an ID ten T moment, but don't these have to be installed in pairs? Got a picture of how it's installed with the new 3 chips?
For some review..
HP ProLiant ML150 G6 Server - Configuring Memory
Memory population guidelines
Standard memory
Memory options
When adding or replacing memory, follow the DIMM installation guidelines that are summarized below:
  • For the HP ProLiant ML150 G6 server with twelve (12) memory slots
  • There are three (3) channels per processor; six (6) channels per server
  • There are two (2) DIMM slots for each memory channel; twelve (12) total slots
  • Memory channel 1 consists of the two (2) DIMMs that are closest to the processor
  • Memory channel 3 consists of the two (2) DIMMs that are furthest from the processor
  • DIMM slots that are white should be populated first
  • Do not mix Unbuffered memory (UDIMMs) with Registered memory (RDIMMs)
  • Do not install DIMMs if the corresponding processor is not installed
  • If only one processor is installed in a 2CPU system, only half of the DIMM slots are available
  • To maximize performance, balance the total memory capacity between all installed processors
  • It is not required, but it is recommended to load the channels similarly if possible
  • You can only have up to eight (8) ranks installed per channel
  • You can only install two quad-rank DIMMs per channel
  • You can only install two UDIMMs per channel; if available, the third slot in the channel must remain empty
  • Populate DIMMs from heaviest load (quad-rank) to lightest load (single-rank) within a channel
  • Heaviest load (DIMM with most ranks) within a channel goes furthest from the chipset
  • For memory mirroring mode, channel 3 must be unpopulated. Channels 1 and 2 are populated identically
  • For lock-step mode, channel 3 must be unpopulated. DIMMs in channels 1 and 2 will be installed in pairs. The paired slots will be 1,4; 2,5; 3;6 on a 3DPC system or 1,4; 2,5; on a 2DPC system
  • No mixing DIMM voltage; all DIMMs must be the same voltage
Specific part numbers for HP RAM kits are in above link...
