JNEWTON
PROBLEM : Re-installing windows vista as client requested. HP no longer sales the recovery discs for this model so I was told to contact computer surgeons where I then ordered the recovery discs. Once I received the discs, I re-installed the OS. The following BSOD's have occurred a number of times during installation: PFN list corrupt, IRQL not less or equal, memory management.
The BSOD's are random and do not always occur, with that said I threw in a good stick of memory and the memory management BSOD continues regardless. Once I got past the BSOD's, I was able to re-install the OS up to a point. It says that it will reboot as its finished installing the OS, upon rebooting it loads windows PE where it issues partition commands and then goes to a white screen with 2 folders transferring files and stays there.
HP says it should stay on the screen for 72 hours, I did that and it continues. Computer surgeons says its a result of a bad sector on the HDD. This pc has 2 hdd's, I have tested both with gsmart control as well as the on board tests and they all come back fine. I tried both hdd's and the same thing happens. I have gone through the BIOS and disabled everything that was not necessary in addition to removing the sound card and nic card. I googled this issue and its common on this model but no one has found a solution.
SPECS :
HP pavilion m8300f
32 bit windows vista home premium
product # GX611AA-ABA
SN: CNX7500PH4
This is the first time I've had a pc problem that I haven't been able to solve and everything that I've listed above I have done 2x or more. The pc is currently on the white page with the 2 folders transferring files and has been there in excess of 72 hours.
If there is anything I missed let me know.
Thanks!
SPECS :
HP pavilion m8300f
SN: CNX7500PH4
Thanks!
