How to import xp ddrescue disc image into vmware
ell
Hi, I've been playing around with vmware workstation, trying to create a windows xp virtual machine from a image created with ddrescue-gui. The image has no extension so I presume it is raw. I have tried the vmware converter, starwind v2v converter, nothing seems to recognize the image. I know the image is fine because I am able to mount it with osfmount and view the files. Not having much luck, ideas?
If you have Linux then you can use use qemu easy enough.
Code:
qemu-img convert -O vmdk ddrescue_image_file WindowsXP_snazzy_name.vmdk
Code:
Thanks! I'm a total linux newb, I'm on it!
You assume correctly that ddrescue uses a completely RAW image file. It's just sector by sector.
An easy way to write it to other objects after is just to add a .bin or .img extension and use a trial of R-Studio or another data recovery program that can work with image files. Then you can just write the image to another image file, hard drive, etc.
thanks!
