How to find a hidden partition?
Canada
This one's got me - any imput glady accepted.
Customer brings in his desktop, says he uses it daily (email, business docs etc.) and now it wont boot up. I diagnose dead MB (no post, voltage fine, new video card and power supply tried , no codes on post card).
He asks for me to recover data includinbg his outlook express folders, address book and about 4500 personal pictures. When I plug his HD into my machine with my ide/sata usb cable windows show 22GB used. When I look for where the space is used using treesize free I can only find 12GB, mostly in the windows and program files folders. I do not see any pictures or.dbx files for his email.
Is there some kind of hidden partition I am not able to access? I tried disk management in XP and it shows the entire 80GB HD as 1 partition. DriveImage XML shows the same. I bought a license for Data rescue PC and I am just scanning now to see if it finds anything.
Any ideas for me? Thanks, as always....
I know that you can find the hidden partition by typing the drive letter followed by a colon in the address field in Windows Explorer, but that's a mystery to me...
There is no such thing as a hidden partition, just an os that refuses to acknowledge they exist. If you feel it is a hidden partition you can boot up your friendly linux distro and at the terminal type "fdisk -l" to list all partitions on all local drives. More then likely there was a second partition that got corrupt, in that case testdisk can do wonders to find the lost partition table, also a linux program but available for windows as well. If you boot the systemrescuecd it has both programs on there, as well as photorec, a data recovery program. May not be as good as getdataback but it has worked for me nicely in the past.
Well to wrap this one up:
I used Data Rescue PC and found all of the missing data. It showed it as being in the usual place, but it sure didn't show in Windows! I have a few other machines on the bench right now - if I have time I'm going to use this as a learning opportunity and try and figure this one out.
I haven't stepped into Linux yet, been putting it off. Saved for another day, I guess...
I don't think there is a hidden partition.... Maybe try to use Partition Magic to be able to check if there an hidden partition. Try this word around.
Not always true, some system builders such as Dell & HP use non-standard file systems to keep their recovery partitions hidden from explorer.
The best way is to use a good partition tool such as PQ Magic, but be careful as you can screw-up the OEM MBR if you're not careful.
Late in the game here, but, did you ask customer if they were using PGP or TrueCrypt or other encryption software?
