KM@ Dave
- Bournemouth, United Kingdom
Thought I'd share my experience with everyone on Laptop Boot/Bootloop problems, it seems I have a high success rate, even though I hate repairing Laptops. I have also seen some very strange things to cause boot problems also.
1.
Check the Laptops I/O ports on the outside of the Laptop, eg. USB ports, Firewire, HDMI, PCMCIA, to see if anything has snapped off in the port(s) as a few of my customers have done this without realising.
2.
If it comes to it, check the cables that lead from the screen, to the motherboard. As over time the they can split, just like a ribbon cable in flip/slide mobile phones, and get damaged if the Laptop is used often. This is typically due to manufacturer flaws in the design of the Laptop as I've picked up along the way.
3.
Just like a Desktop Computer, a Laptop can be rendered unusable due to faulty hardware, for example: the DVD Drive, RAM, Graphics Card (If dedicated, else you're screwed), Hard Drive, Wireless Card. Here's my point, if you can remove it, do it. I boot Desktops experiencing boot problems with just essential hardware, and most of the time it helps.
4.
Check the Battery connector pins, I know this is uncommon and I've never encountered this problem, but I do check every time I face a Boot/Bootloop problems as maybe it is the source of error.
5.
Well this is a very rare one, and I've only seen it once. The Wireless Card's signal/reception cable, I have caught this little bugger sitting between two components before, thus causing a short within the Laptop. It seemed the 'customer' had fiddled with the Laptop before and obviously left the cable dangling about inside thus causing a short.
6.
The CPU fan... well this is the most annoying one. Some Laptops have a failsafe built into the BIOS, and upon detecting a broken, non-connected CPU fan the Laptop doesn't even start up, or twinge! So check it, you'll be surprised.
7.
Sometimes a Laptop can be rendered unbootable due to the keyboard developing a fault, I haven't seen this much, but it has still happened so it may be something to check also.
END
I hope this helps some of you, and I am also open to other things to look out for, and maybe add over time.
1.
2.
3.
4.
5.
6.
7.
END
