Big Jim
- Derbyshire, UK
As i have a card machine connected via ethernet, I have to perform a network scan as part of my compliance.
Its an online portal, I login give it my IP then a couple of hours later it throws the results at me.
It found 31 vulnerabilities, 10 of which have caused me to fail my audit.
9 out of the 10 were related to port 443, so I set a firewall rule in the router to block 443 completely, ran the test again and I am still getting the exact same results.
The problem is I do not understand the results one bit, for example see attached.
I am using a draytek Vigor 2850N router.
i run 3 seperate Vlans
1 for our internal network
1 for customer network
1 solely for the card machine
